Question about Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher
Diswasher doesnt clean and leaves
Maytag dishwasher, less than two years old. Doesnt clean very well. Cups, especialy ceramic ones on top shelf have a grimes and gunk caked into them at end of cycle. SOmetimes not all, washer makes a grinding sound when it starts up, seems unrelated to washing problem. i use a solid pellet type of dishwashing detergent (Electrasol) and have rinsed with vinegar which is only partially helpful, first wash is cleaner but not spotless. MDB6601 use liquid soap and jet dry but glasses still have sand size food particles that dont rise off. Unit drains intirely, makes no strange noises and was installed in 2007. Ran ok for first year but now it takes 2 cycles to get clean and usually end up hand washing them anyway.So why do I need dishwasher.
  • Todd McCormick May 11, 2010
    do you have city water or well? water softner? I have installed softners on a city water system!
  • Maytag Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 30, 2010
I have a maytag quiet series 300, dishes dont get clean on top rack and sometimes it doesnt drain. do i need to clean some trap or drain?
Check the screen area around the sump right below the lower spray arm if it is built up with lime deposit then the wash pump is starving for water and cannot pump water to the upper spray arm this would also starve water to the drain pump.
Mar 06, 2014 | Dishwashers
Bosch Diswasher
Remove the drain hose and check if you have any residual into it. After 11 years your appliance may need a thourought cleaning.
Check also if the pump has enough pressure.
Apr 22, 2008 | Dishwashers
Doesnt clean everything , leaves residue in
check the water connection that goes to the machine, if there isnt enough water getting into the machine then it dosnt clean as well.
the connection might be a little bit clogged.
Apr 20, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Our Maytag quiet series 200 does not clean or rinse dishes properly. It leaves film all over cups and dishes. Water also seems not to be draining out. It is 6 years old
It is not the dishwasher. The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Sep 07, 2009 | Maytag Dishwashers
Ingrained glass on top shelf
Hello. Begin by running the dishwasher after adding two cups of vinegar. Use the hottest and longest cycle u have. This will clean your machine. Then change over to cascade liquid and see if it imakes a difference. Finally, always run the hot water in the sink until it is real hot before you turn on your dishwasher.
Jul 06, 2009 | Dishwashers
Dishes still dirty after wash cycle
It would be real helpful to have you provide the manufacterer and model number to get more specific with solution.
-Have you changes dishwasher soap powder recently? Buy a box of Electrosol or Cascade and see what happens. The ultracheep versions actually have caused cleaning problems, especilly in water-conserving dishwashers.
-Under the lower rack is the sump area with a filter that can be removed, usaully by removing several screws. Pull that filter, rinse is as best you can. Inspect under where the filter was and remove all debris. Watch out for broken glass that is found in most well used diswashers, it is hard to see and sharp! Reasemble the filter.
-If problems continue and if this diswasher is several years old, plan on getting the wash pump motor replaced (or replace the diswasher with a name brand, Energy Star model.) Good Luck!
Please update me with what you found. OK?
Mar 30, 2009 | Dishwashers
Diswasher doesnt clean and leaves "gunk" on top shelf items
The rinse agent is a separate product. I use CascadeCrystal Clear in a 16 ounce bottle. In your machine (if it's anything like mine) there should be what looks like a screw cap next to the soap dispenser. Unscrew that and pour in the product.I was told by the appliance store where I bought my machine that you have to use this in stainless steel washers. Also I would try a liquid type soap. I use Cascade with shine shield. I think from past experience that the pellets aren't very good especially if you have hard water.
Dec 16, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Top rack not cleaning
load 4 cups right side up in all four corners of top rack, move all wash arms to a known positon(pointing foward just want to check there rotaiton). start diswasher, when you hear it start washing give it 30 sec or so andpop it open try to focus on middle spray arm when opening, shlould be turning quite well. and glasses sould be starting to fill. at least thats how it SHOULD operate
Feb 25, 2008 | Dishwashers
Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher Logo
340 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
