Regal Ware K6725 Kitchen Pro Bread Maker
Problem for Regal Ware K6725 Kitchen Pro Bread Maker
Need a new belt for the Regal K6725 bread maker
By maybellene1 on May 31, 2009
Belt is worn. There must be a replacement out there some place Looking for a belt for a K6725 Regal Kitchen Pro machine.  Bought it on cheapcycle and belt slips.  Located in Ontario... Thanks maybellene1@gmail.com
Solution #1
posted on Sep 13, 2009
Not Rated)
billypat
Rank: Master
Rating: 100%, 7 votes
Hi, I have the same machine and the belt was in tiny rotten pieces...I wound a piece of yarn around the wheel and drive shaft (lie the machine on a kitchen counter, lid open and hanging down off of the counter, bottoms up, and remove the screws from the teardrop shaped brass colored safety cover, remove the cover and expose the wheel and drive shaft) pull the yarn tight and knot it. Then cut the yarn about an inch from the knot. Measure the yarn when pulled on a little. Mine measured 23.5"....I then googled bread machine belt 23.5" and up came one for an Oster Bread Machine (The one I was repairing was a Regal Kitchen Pro 6725) from totalvac.com located at 2 De Bush Ave Unit A8 Middleton, MA 01949
It was $7.95 for the belt, $6.95 S & H to a VA address, total cost $14.90 so I decided to give it a shot. When it got here, I removed the safety cover, held the machine up and shook as much of the old rotten rubber belt pieces out as I could, and replaced the belt by placing it over the sticky string on the drive shaft and teasing it over the wheel. It is an exact fit. Be sure the ribbed side of the belt is down against the wheel. Screw the cover back on and run it through a dough cycle so that the belt will get coated with the sticky stuff from the sticky string on the drive shaft. Until the belt is coated, it will turn the mixing blade, but it will slip. Hope this helps. Patti
Patti Wilson
September 2009
Comments:
Sep 13, 2009
- Hi, I have the same machine and the belt was in tiny rotten pieces...I wound a piece of yarn around the wheel and drive shaft (lie the machine on a kitchen counter, lid open and hanging down off of the counter, bottoms up, and remove the screws from the teardrop shaped brass colored safety cover, remove the cover and expose the wheel and drive shaft) pull the yarn tight and knot it. Then cut the yarn about an inch from the knot. Measure the yarn when pulled on a little. Mine measured 23.5"....I then googled bread machine belt 23.5" and up came one for an Oster Bread Machine (The one I was repairing was a Regal Kitchen Pro 6725) from totalvac.com located at 2 De Bush Ave Unit A8 Middleton, MA 01949
Patti Wilson
Sep 13, 2009
Patti Wilson
Sep 14, 2009
Patti Wilson
Was this helpful?
Yes
No
Popular Solutions for Regal Ware K6725 Kitchen Pro
Questions and Unsolved Problems for Regal Ware K6725 Kitchen Pro
Do you recommend Regal Ware K6725 Kitchen Pro Bread Maker?
Answer
Answer
My belt broke and I need to know where I can get a new belt for my regal bread maker model #K6725
Answer
When I make a loaf of bread, I have a huge hole in the bottom of the loaf. The hole is surrounded by... (More)
Answer
I need instuctions on my Kitchen Pro (Regal) bread machine
Answer
My Mom gave me a Regal Breadmaker (Kitchen Pro Collection) model #K6725 and there was no operating... (More)
Answer
I have lost my manual for my Regal bread machine, and am in a bit of a hurry. I have put the mix... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Bread Machine Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
