Question about Whirlpool Dryers
Dryer not heating
I am getting no heat
  • 6,784 Answers
For a gas dryer, check the following---
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
For a electrical dryer, check the following---
. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Posted on Jun 01, 2009
Gas Dryer Heat wont stay on.
Must be something in the blower section. You need to get into the dryer and clean it up. Air restrictions cause overheat condition. When the temp gets so high the limits shut it down. Lots of videos on you tube that show how to get into. You can google gas dryer dan webster or roper dryer no heat dan webster and I have some videos posted how to get into these.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 14, 2014 | Whirlpool LGB6300 Gas Dryer
No heat. maytag model # MDE8057AYW
Hello there and thank you for choosing fixya
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
tbirdfan1_21.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
tbirdfan1_22.jpgThermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
tbirdfan1_24.jpgTimer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Jan 23, 2011 | Maytag Dryers
Quit heating
ok there are a few reasons why this happnes i will post them below for you
Proper Voltage
Heating Element
Jan 22, 2011 | Dryers
Dryer stopped heating...what to do?
Hello there
Proper Voltage
dryer_heating-element.jpg Heating Element
dryer_thermal-fuse.jpg Thermal Fuse
dryer_thermostat.jpg Thermostat
dryer_timer.jpg Timer motor
Dec 08, 2010 | Dryers
Ge profile dryer drum turns but therte is no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 27, 2010 | GE Dryers
Whirpool dryer 10 years old is still heating but taking very long to dry clothes. Checked dryer vent and it is clear. Will heating element help?
If your heating element is still heating up the cause lies elsewhere. Filter for dryer both at the base of dryer and filter location . If you are getting heat then airflow is the problem. how is the fan motor in front of heating element
Mar 09, 2010 | Whirlpool LER5636P Electric Dryer
Will run but won't heat
HELLO THERE
There are 5 things that can make a dryer not heat please review the following items that i have provided for you
investigate these five areas if your dryer is not heating up:
Proper Voltage
Jan 18, 2010 | Whirlpool LER4634J Electric Dryer
The dryer does not give heat
Hello there:
Proper Voltage
8574d88.jpg Heating Element
d5b5af3.jpg Thermal Fuse
77d6bd4.jpg Thermostat
Jan 14, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Accessing the heating element
I have a ALE643RB Amana dryer and believe the heating element has went out because the dryer will not heat anymore. I have taken the control panel off the top and all the screws out on the back and the bottom edge, but am still not able to get the shell off the dryer. How do you get to the heating element?
Feb 08, 2008 | Amana ALE643RB Electric Dryer
Dryers Logo
104 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
