Question about Hotpoint Ariston WD440G Front Load All-in-One Washer / Dryer
Hotpoint Aquarius WD440G
Hi, can you help I have a hotpoint aquarius WD440G, I have switch machine off however the option lights (drying heat, reduce crease, rinse hold, extra rinse) are all still on light bright red??? puzzled as i have switched machine off and can't get lights off have tried switching machine back on pressing start/cancel button along with on/off button however still alight when on off button is off. Can you help?
  • Hotpoint Master
  • 10,291 Answers
Unplug the machine from the wall for 5 minutes, then plug it back in and try it again. If the lights come back, the control board needs to be replaced.
Posted on Jul 28, 2017
  • 57 Answers
SOURCE: hotpoint aquarius wd440g washer/dryer
Hi claire your problem is the pump braking down check to make sure there is nothing in the pump if you still cant get the door open pull the mains plug out and turn off the water valves red and blue take off the top of the machine and get a basin take the drain hose out and put it in the basin and bring the two down to the floor empty all the water out you should now be able to get the door open remember to check the pump and the bearings
Posted on Jul 28, 2008
ngafm
  • 166 Answers
SOURCE: Hotpoint aquarius wf320
Hi charlie99 Peace,
ngafm At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT.
If not only a trained laundry tech can make the electronic diagnoses.
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Thank You
Posted on Sep 10, 2008
  • 3 Answers
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Posted on Oct 23, 2008
reddyanantha
  • 205 Answers
SOURCE: hotpoint aquarius wd440. Flashing lights
hello mam please check the timer switch.
Posted on Oct 04, 2009
  • 662 Answers
SOURCE: Hotpoint Aquarius not completing finally spin and pumping out
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter is inside the machine. Turn off the power and pull out the machine to get to the rear. Pull out the hose you see going into the wall pipe, lay at floor level or plastic bag to drain out remaining water in machine. Remove the panel at the bottom (2 screws) where the discharge hose comes out. You should see a black concertina type tube coming from below the drum attached by a jubilee clip. The filter is inside. Loosen the clip and pull away the tube, take out the filter and clean it. When you replace it don't forget to put the ball float back in (exactly as you found it) and check it’s well fixed by running a spin cycle before sealing up. Caution, the exit drain hose shd be fitted at the exact location where you found it, abt three feet up from ground level.
Pl rate me nice for the free help, thnks.
Posted on Jun 04, 2010
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Error code on my Hotpoint Aquarius WF240
my hotpoint Aquarius wf340 when switch on 5 secs later on/off button flashing along with mini load lights. could u tell me the error codes for this machine?
Apr 04, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint DW440 flashiing lights
I have just seen the same problem on a neighbours WD440G. I have tracked down the problem to the main circuit board at the back, bottom of the machine. Transistor/FET Q9 has exploded. There was water at the bottom of the machine and the wiring in the vicinity of the nearby connector was wet.
This neighbour is in no financial position to be able to buy a new board, or get an official Hotpoint engineer to confirm what we already know. Anyone know where I can get a schematic diagram for the board?
Dec 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Oct 31, 2008 | Hotpoint Aquarius WD63 Front Load...
My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wd440g washer/dryer
Jul 27, 2008 | Hotpoint Aquarius WD63 Front Load...
WD440G. No heat in wash and dry.
I would first check exhust vent to make sure it's not clogged if so it will cause your heating sensor to shut down
Mar 28, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD440G
I SWITH ON THE MACHINE AND F 01 APPEARS
Aug 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ariston WD440G Front Load All-in-One Washer / Dryer Logo
65 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
