Question about Dishwashers
Lock on led keeps flashing. Can not cancel it, when pressed it also starts flashing. Control touch pad not functioning. When able to get going usually after turning off power for a while, it does not complete the cycle and the lock on led starts flashing again. Thanks
  • 1 more comment
  • meclay123 May 31, 2009
    This problem has been going on quite a while. Yhe dishwasher does have water in it, it has not completed the wash cycle and drained it. M # 665.15979990, St # 15979, Se # FJ3402944
  • meclay123 Jun 02, 2009
    Tested the door switch with an ohm meter and found a closure with door closed and an open with it open. Tried several times opening and closing and found the same result. When lock on led is flashing just grabbing the handle as if to open the door stops the flashing and when released flashing restarts.
    I have turned the power back on to the dishwasher and the red lock on led flashes. I tried pressing and holding the NO HEAT DRY button that has the lock symbol on it but it did nothing. Next tried pressing the WATER HEAT & NO HEAT DRY keys, do not see keys labeled HIGH TEMP & HEAT DRY. No other led's came on after pressing this sequence of keys. Tried this several times. I believe they are the correct keys to be pressing. If not please advise.
    The keys on my washer in order are, FAVORITE CYCLE, POTS PANS, NORMAL CYCLE, WATER MISER, CHINA WASH, QUICK RINSE, WATER HEAT, SANI RINSE, NO HEAT DRY w/ LOCK SYM., DELAY HOURS, CANCEL/ DRAIN, & START. Thanks
  • 122 Answers
The flashing lock light problem might be caused by a stuck key on the touch panel console.
If the control board detects that a key is stuck, then the dishwasher will suspend operation until the key is unstuck. If a key without a light is stuck or multiple keys are stuck, the control will flash the Lock light.
The way to fix this is to replace the touch panel console.
Posted on Jun 03, 2009
    Sergeant:
  • 187 Answers
look for the lock symbol, it should be on the heated dry pad. Press and hold it until the lock led turns off. if that doesn't do it, press the keys in this order..high temp-heated dry-high temp-heated dry. All lights should light and it will go into the test mode. Advance it through the test mode by pressing start until it finishes.
please rate my suggestion..........
Posted on Jun 02, 2009
  • karthik
    karthik Jun 03, 2009
    if you've made sure the control panel isn't locked-out by holding the No Heat Dry button for 4 seconds, also try pushing it 4 times.
    Then if that didn't work, its your control panel thats bad.It should be replaced..
  • 431 Answers
Hi I am Vortash it sounds very much like the actual door lock switch is either faulty ( the switch that tells the machine programer the door is shut and allows the cycle to start ) or the programer itself has a fault and is not recieving the signlal . I think the latter from what you say the machine cools ( programer ) and it opperates for a while till fault re occurs in the programmer and stops the cycle because it says the door has been opened .and that is after you unplug it for a while .. if it did it all the time I would have thought lock switch .. but I am thinking you need a new programmer or at least that one repaired .. cheapest thing to try first is a new door switch to see if it cures the problem .. regards Vortash
Posted on May 31, 2009
  • 19,396 Answers
To start turn control on off position. Trip the circuit breaker or unplug the power cord and connect everything back.
If that reset the machine then the problem had been just temporary.
If that did not work, then proceed with some basic troubleshooting, checking if there is water inside the machine, checking and unblocking the drain hose, unblocking drain pump hose, and if cycle starts checking if water is getting inside the machine from inlet valve. Also ensure that the inlet hose is not kinked, and that water is flowing with pressure from the water supply at the back.
If that does not help , then you start the real troubleshooting and repair.
In that case let me know the make and model, getting model number printed on service tag would be better.
Thanks.
G.
It tries to start but then the start light keeps flashing
Hello John Schmader - Sounds like the washer could be experiencing a communication error with main control board, faulty door lock assembly, pump or the timer itself is not operating correctly. Is the unit making a humming noise? If so, either the drain hose or pump is clogged and needs to be cleaned. Does the washer display an error code? Try pressing and holding the START and PAUSE/CANCEL button simultaneously. All LED's will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LED's. The control will repeatedly signal the code, as long as the START and PAUSE/CANCEL buttons are pressed. A two second pause between repeats affords you the ability to make accurate counts to identify an error (if one displays).
Jan 26, 2013 | Frigidaire GLTF2940ES Front Load Washer
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Control lock on duet washer GHW9250ML1 is flashing, nothing working even after unplugging. When replugged, light starts to flash again and nothing else.
    Here's what the Duet tech sheet says to do:
    1. Press PAUSE/CANCEL button on the touch-pad twice.
    2. Drain the unit, then check that the Drain hose and Drain Pump
    Filter is clear of foreign objects.
    3. Check/ Replace Touch-pad/LED assembly.
    4. Check harness connections.
    5. Check the CCU.
    Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Display shows E0 F2 after pressing start and cancel at same time. No other buttons work. Stovetop still works.
    F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
    Select the 'cancel' function and wait 60 seconds.
    If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    May 14, 2010 | Whirlpool GY398LXPS Electric Kitchen Range
    What does the sign "control lock" mean?
    Here is what the manual for your oven says about control lock.
    Let me know if you have questions.
    Control Lock
    The Control Lock shuts down the control panel pads to prevent
    unintended use of the oven(s). The Control Lock will remain set
    after a power failure, if set before the power failure. The only time
    it is not available is during the Sabbath Mode or Self-Clean cycle.
    When the control is locked, only the TIMER SET · START, TIMER
    CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
    CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
    function. On double oven models, CLOCK SET · START will also
    function.
    The Control Lock is preset unlocked, but can be locked.
    To Lock/Unlock Control: Press and hold CONTROL LOCK for
    about 3 seconds, until “CONTROL LOCK” and a picture of a lock
    appear on the display. Repeat to unlock and remove “CONTROL
    LOCK” from the display.
    May 13, 2010 | KitchenAid SGL OVEN T/C
    Control locked light is on and washer won't turn on. Can press "Control On" and Cancel/Pause buttons at the same time to get the power on but won't start.
    Looking at the manual of my Whirlpool front loader gives me the following advice...
    CONTROL WON’T ACCEPT SELECTIONS
    2. Drain the unit, then check that the drain hose and drain
    pump filter are clear of foreign objects.
    3. Check the touch-pad/LED assembly by selecting different
    cycles and changing the modifiers and options available to
    confirm the touch-pad/LED is responding.
    4. Unplug washer or disconnect power.
    5. Check harness connections.
    6. Plug in washer or reconnect power.
    7. Verify CCU operation by running a Diagnostic test or any
    cycle
    BTW: The full manual is at http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208182208.pdf
    Mar 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Codes F-21 And F-33 are showing up
    this error occurs if the touch-pad/led assembly is not able to transmit/receive data to/from the central control unit (CCU) 1 check the touch -pad/led assembly by selecting different cycles and changing the modifiers and options available to confrim the touch-pad/led is responding. 2 unplug washer or disconnect power. 3 check wire harness connections to the touch-pad/led assembly and central control unit (CCU) now to the f-33 code system leak if after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed. OR if the control has turned the water valves on and after 8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. press PAUSE/CANCEL twice to clear the display. possible causes/procedure 1 check for crack or holes in the washer tub and pressure switch hose. 2 replace components if necessary good luck
    Feb 16, 2010 | Maytag EPICz 3.7 cu. ft. Washer
    Waste ink aborber
    you can see it and partially clean it without striping the printer down, but after taking the printer top off you can give the whole area a good clean.
    The tank is the little plastic tray to the right of the carridge, its about 1cm x 2 and a half and has an absorbant pad inside it held in by delicate rubber wings, the pad can be taken out and a metal plates sits below which can also be removed revealing a small tube throught which ink passes.
    You can strip all of this out and clean or just give a quick wipe out with cotton buds without dismanteling too much.
    I would recomend that if you have the time and patience then at least do the following;
    Take the absorbant pad out and keep patting it on kitchen roll etc until no more in comes off, then gently clean around the rest of the tank with cotton buds, this should be enough cleaning to keep everything happy!
    The worst you can do is be a touch to rough and knock the small spring out of place that sits under the tank (you will feel this spring as you prod at the tank) the spring is a pain to get back in place!
    Try this to reset the error.
    1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
    2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
    3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
    4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
    5) Press the Power button. The LED lights in green, and the
    selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
    6) Power off then back on and test.
    Jul 21, 2009 | Office Equipment & Supplies
    Lost my manual for chef condor integra oven - need to check auto functions and how to set them
    For TOuch Control oven:
    1. Press Finish Time touch pad
    2.press ^ touch pad until clock displays the required am or pm finish time.
    3. Press Cook Period touch pad.
    4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
    5. Press Automatic touch pad.
    Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
    7. Turn oven thermostat to desired setting.
    8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
    10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
    For Multifunction oven:
    1. Set time of day.
    2. Turn Function switch to Finish. 0.00 will be displayed.
    3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
    4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
    5. Turn Function switch to Auto. The automatic programme is now ready to use.
    Turn upper oven thermostat to desired setting.
    If keep warm function is required, turn function switch to Cook (optional)
    Happy cooking!
    Jun 14, 2009 | Ovens
    F9 Code after power outage - Model JGR8855ADS
    Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
    You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
    If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
    Generic:
    Fault Code Interpretation Components To Check
    F-1 Communication error between touch pad and ERC (clock)
    Replace the touch pad or clock.
    F-2 Oven temperature sensed by electronic control Replace the clock/relay board
    F-3 Open oven sensor or harness. Replace the oven sensor
    F-4 Shorted oven sensor or harness Replace the oven sensor
    F-5 Power to element relay disabled in cook mode Replace the clock/relay board
    F-7 Shorted touch pad key sensed for 32 secs. Replace the touch pad/control panel
    F-8 Shorted meat probe Replace the probe jack.
    F-9 Door lock safety circuit on ERC sensed Replace the door latch assembly
    F-C or F-0 Communication error between boards Replace the relay board
    Maytag-Maycop-Magic Chef-Jennair-Admiral: Oven Fault Codes:
    F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
    F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
    F2 Oven over heat defective Relay Board or (if present) or defective Sensor
    F3 Oven Sensor Open Replace Sensor
    F4 Shorted wire or Sensor locate short and correct it or replace Sensor
    F5 Hardware, safety circuits disagree Replace Clock
    F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
    F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
    F8 A/D Warning Replace Clock
    F9 Door Lock Warning Check door lock circuit or Replace Clock
    Mar 09, 2008 | Jenn-Air JGR8875QDS Gas Kitchen Range
    Dishwashers Logo
    105 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
