Central air unit runs and vent are cold but no air flow
The central air unit runs and the blower motor is running and the vents are cold but there is no air flow through the vents. When the heater is on I have air flow. What could be the problem? Help!
  • jr95416 May 31, 2009
    Every thing seems to be operating but just not getting air through the vents. Could it be freezing up to not let air through?
  • 822 Answers
Check sensors and contactors.
Posted on May 31, 2009
I have a uaka-018jaz outside Central air unit. The other day the unit is still running but nothing is blowing out of the vent inside house in floor. The condenser or coils in the vent frosted
First you have to make sure the blower motor is running. That is the fan motor on the indoor unit. If the fan inside is running and the filter is clean you are likely low on refrigerant. If the indoor fan is not running this would be the reason for the frost. If the unit is iced up turn the system to off and the fan to on on the tstat. This will help defrost the coil. Good Luck.
May 06, 2017 | Heating & Cooling
Goodman central air conditioning. Little air is coming from the vents in the house and the air that is coming out isnt very cold
have the central unit blower/fan cleaned as they block up from dust and other particles so that they eventually look like logs and do not move air like they should. Have the unit gas pressure tested for correct amount of gas
Jun 17, 2013 | Heating & Cooling
A/c blower turns slow and makes puffing sound. bryant 80% avac system.little cold air from vents
Hello, replace the capacitor as when there are storms sometimes they can cause a voltage spike and damage the capacitor. The capcitor will be a round or oval metal looking can next to the motor. When the blower motor runs slow the coil can start to freeze due to lack of airflow and this is why little air is coming out of the vents. If the capacitor does solve the problem then the motor will have to be replaced.
Jul 01, 2012 | Bryant Heating & Cooling
I live in an apartment that has Airtemp central air. The unit blower runs but the air is barely cool. Maintenance sys there is nothing wrong with the unit. What could cause this problem?
air temp should drop 15-20 F across the a/c coil a rule of thumb i use is air temp out of the vents 10-15 F less than room temp on thermostat if the air out of the vents isnt that cold the a/c is either leaking and undercharged or return air temps are to high. is the inside unit in an attic? return leakage in this situation can cause high supply air temps but look like every thing is ok when pressures are checked at the outside unit
Jun 15, 2010 | Heating & Cooling
Cool air, but no fan, electrical smell inside house
most like it the motor windings are burn and you need to replace the blower motor
Sep 27, 2009 | Ruud UBHC Air Conditioner
Air condtioning unit
check capicitor on motor, fan motor bearings may be locking up when they get hot then when cooled the motor comes back on. Then you must replace fan motor.
Aug 11, 2009 | Heating & Cooling
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Car does not blow air.
For starters, do you hear the blower motor running when you turn the heat on? If it does blow is there any airflow coming from your air vents? If the blower motor runs and there is air flow from the vents there are a few other tiems to check. Veriiffy that the coolant is full, low coolant level will effect the flow of coolant to the heater core. If coolant is full you may have a clogged heater core, or one of the blend doors ( they regulate air flow between the A/C evaperator and your heater core) may be malfunctioning or the control head(temp control) is malfntioning.
Jan 13, 2009 | Hyundai Motor 2003 Sonata
No air flow upstairs
Cold air is denser than hot air, so is harder to move. All vents have some mechanism to regulate flow, so close all of the downstairs vents. Check to see if your furnace fan motor has more than one speed, & set it on maximum. Keeping the fan on all the time will help as well. If all else fails, you may need a more powerful fan motor.
Jun 16, 2007 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
266 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
