Question about Kenmore Dryers
Propane dryer. Can hear the heat kick on but dryer doesn't heat
We have a Kenmore 80 series dryer. Model # 110.72822101. Propane. It won't heat. Turn it on and you can hear the heat kick on but the dryer doesn't heat up. We have removed the back and cleaned out the lint shoot, fixed the ventilation system coming from the dryer to the outside. Occasionally it will warm up slightly but not enough to dry the load. Help
Try looking at the gas regulator. It should have a solenoid that opens and closes. It sounds to me like this is not opening or is only opening partially. I had this same problem on an oven.
Posted on Jun 01, 2009
My series 80 Kenmore dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 30, 2011 | Kenmore 800 6983 Electric Dryer
Dryer rotates, but there is zero heat. Kenmore Series 80, model 0104806
First check your breakers in the power box to the house. If one the the legs is tripped, the cylinder will turn but will not heat. Next, check the thermostat switches near the heating element for continuity. If no continuity, replace them. Check heating element for continuity. If no continuity, replace.
Aug 08, 2010 | Kenmore 84052 Dryer
Kenmore propane clothes dryer not heating
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jun 01, 2009 | Dryers
Dryer wil not spin
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 08, 2009 | Dryers
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Dryers Logo
240 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
