Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
NOT GETTING FIRE TO THE SPARK PLUGS for a leaf blower
WILL TURN OVER . BUT NOT GETTING FIRE TO THE PLUGS. im not gettin spark? for a leaf blower
  • 61 Answers
Bad coil, or bad off on switch.
Posted on Sep 06, 2009
No fire on echo pb200 leaf blower
I would check to see if the spark plug is firing first off and if it is ok check the plug wire and make sure there is no damage to it. If that is ok then you probably have a bad coil. You can use a spark plug tester and see if you are getting fire from the coil if not you will need to replace it. If you change the coil be sure to note the air gap between the coil and the flywheel then set the new one to approx. the same distance. Hope this helps.
Sep 29, 2016 | Echo Garden
Getting spark and gas but won't start,it will fire once and a while and pop but that it,help
Check compression, vacuum and pressure check, ring seized to the piston. Also if you haven't replaced the spark plug, do it. Sometimes it's the most simple things that stump us. Sometimes a spark plug won't fire under load.
Sep 28, 2014 | Homelite Leaf Vac Attack
Not geting fire to the plug
Hi Dennis
Hi
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Bud
Oct 10, 2013 | Ryobi Ry09050 26cc 200mph Gas Handheld...
How can I check to see if my fl1500 weed eater blower is getting fire
Pull the spark plug boot off, hold it near the block or another metallic surface and pull the starter (all of this needs to happen in a darkened room). If you see a spark, you know that it's getting spark.
Aug 29, 2011 | Poulan Featherlite Gas Blower, with Low...
CRAFTMAN LEAF BLOWER WONT START
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 19, 2009 | Craftsman 4 Cycle Blower/Vac
Unable to start my 155BT blower. Have changed
Is the new spark plug wet? If not, the machine is not getting fuel (fuel filter, carb, etc.) If the plug is wet, you may not be getting spark (bad ignition module, short in switch/harness, bad plug (yes it does happen with even new plugs)), or flooding due to incorrect starting procedure or clogged airfilter. Stale fuel can also cause an engine not to start as it lacks volatility. If in doubt, take it to your local dealer.
Oct 22, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
Craftman gas leaf blower stopped working suddenly. I changed the spark plugs but it still won't start
first check for spark, if you have spark gap plug at .030. turn mixture screws completelin give a short squirt of carb cleaner directly into throat of carb and try to start if unit starts then dies ,carb needs to be rebuilt and also change fuel filter in the gastank. gas mixture 40:1
Sep 05, 2009 | Garden
It will not start. new spark plug. gas mixture is
If the leaf blower has been setting up for a while there is a possibility that the jets in the carb are clogged up,and it's not getting gas into the engine. Or the spark plug may not be getting any fire, you can check this by removing the plug and and grounding the end where the gap is against a metal part of the engine and letting someone pull the starter cord while you watch closely to see if a spark jumps across the gap, but be very careful you don't want to cause an explosion from gas fumes. If you don't feel comfortable doing this you may need to take the leaf blower to a repair shop and have it serviced.
Aug 20, 2009 | Garden
Homelite ut08107 will not fire. no spark at plug.
It may be the coil if there is not any spark. Or a wire could off at the coil. One more thing it could be is the spark plug wire may have came loose from the coil. These a few thing to check.
May 04, 2009 | Garden
McCulloch 32cc backpack leaf-blower
Mcculloch MB3202 anti-vibration back pack leaf blower, runs better at the middle setting of the choke than it does if it's wide open the way it should be. Can't get it to blow leaves well. Owners manual lost. ANY ADVICE???????? New gas, spark plug starts on the first pull but just doesn't give out like it should.
Nov 07, 2008 | McCulloch 26cc Backpack Blower with Dual...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
248 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
