Question about Nikon Coolpix 5600 Digital Camera
Lens error dropped camera, landed on lense and now lense is jammed and won't open..its a Nikon E5600
    Brigadier General:
  • 3,614 Answers
There;s an stuck up on the mechanical gear inside cause of sudden outage of battery, i don't really advice this but try to soft slap on the device just to make that disalign gear back on.
update me more here!
Posted on May 31, 2009
What's your problem? MY LENSE WON'T GO IN
The gears in the lens are jammed due to gear ware, or dirt and grime,"more likely" It will need to be dismantled cleaned and lubricated in order to address, price will be a big consideration when contemplating what to do.
Apr 14, 2012 | Nikon COOLPIX L18 Digital Camera
Nikon coolpix s8100 lens error lens won't retract
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 07, 2011 | Nikon S8100 Digital Camera
My daughter dropped her camera and and the lens is now jammed. turning it on and we see "Lens Error" on the back screen.
the error is inside the camera on its lens. it's lens can't move bec it was dislocated.you should go to the camera service center.they will be the one to open the camera & check on it.
Oct 20, 2009 | Nikon Cameras
Lense error- can hear lense trying to open, but lense does not come out of the camera body. This is weird because the camera was not dropped/hit/damaged. I used the camera to take night images of a rising...
The camera seems to have some lens problem.
Now, that said, let's try.
If you can get to the menu, reset all to default.
If that does not work, then the camera will need the lens to be repaired.
I would suggest you call Nikon.
go to nikon.com find the toll free number under support. They will tell you what to do. This camera may still be under warranty.
Sep 08, 2009 | Nikon COOLPIX P80 Digital Camera
Lens will not open
Try pushing the lens gently inside then side to side. It should zoom right out when turned on. It happened to my S70 coz when my kids played with it dropped it.
May 23, 2009 | Nikon COOLPIX S60 Digital Camera
Lens do not open
try smacking the sides of camera.also try to make the lens up down with you hand couple of times.then check out.
Mar 23, 2009 | Cameras
I dropped my Nikon L18 and it now says lens error when I turn it on. And the lens wont go back in.
you jammed the lense neds to be taken to a camera repair person It needs a new lense assmbly .
Jan 01, 2009 | Nikon COOLPIX L18 Digital Camera
Nikon coolpix p50, lense error, camera won't work lens stuck.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 28, 2008 | Nikon COOLPIX L18 Digital Camera
How can i fix a stuck lens on a Nikon COOLPIX L11?
It worked. I just gently nudgged the extended(stuck) lens to one side by hand. (the side which had the gap.) There was a click sound and the lense housing fell back in place. Sweitched off and switched on again and the lense started working fine. thanks.
Oct 18, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon Coolpix 5600 Digital Camera Logo
263 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
