Question about Mantis Tiller
Mantis tiller will not start
Was working until it ran out of gas yesterday, found that primer bulb was busted, husband replaced bulb but now can not pull cord to start
  • sdbrady411 May 31, 2009
    has gas & oil mixture
    Sergeant:
  • 179 Answers
Did it also run out of oil, because it seized like it did you might of burnt the engine
Posted on May 31, 2009
Just bought a carb kit. Which way does the diaphragm go in ? Also,the primer bulb won't show gas.
if the primer bulb cannot pick up fuel and the fuel lines are good then you have a bad primer plate and you need a new carb
Mar 25, 2015 | Mantis 2-Cycle Tiller
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
Vapor lock on Mantis
check the fuel lines for a breakage or the primer bulb for a crack. Sounds like it is sucking air instead of fuel
Jan 06, 2013 | Mantis 2-Cycle Tiller
Mantis power surges
clean or replace carb.
May 17, 2012 | Mantis 2-Cycle Tiller
Can not find my manual for the mantis tiller..forgot hot to start it up for the first time
You should be able to go to the Mantis web site and download the owners manual. To start, make sure the switch in turned on, push the fuel primer bulb several times (until you feel resistance), pull the choke out all the way and pull the starter rope until it fires. Then, push the choke half way in and it should start. Let it run a 30 seconds to 1 minute and then push the choke all the way in. Be sure you are using the currect fuel/oil mixture with fresh gas and oil. If you have not done so already clean the air filter and replace the spark plug at the recommended interval.
May 23, 2011 | Mantis 2-Cycle Tiller
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Bulb and gas lines are OK why does gas leak out the Carb.? I ran the tiller yesterday but today it will not start and the entire gas tank emptied out thru the Carb. I have not adjusted anything
most carb problems can be remedied with a carb. kit & cleaning.
However, this problem is solved by replacing the carb. 95% of the time.
not exactly what you wanted to hear.
Sep 09, 2009 | Mantis 2-Cycle Tiller
Mantis tiller won't start,does not seem to be getting any fuel in
if the primer bulb isn't filling up with gas when you push it the the diphram in the carb. behind bulb is bad needs to be replaced then it should work unless fuel lines are crossed or has holes in them
Jun 08, 2009 | Mantis Tiller
Mantis tiller no fuel getting through to the primer bulb
the fuel line may be clogged or is collapsed go to a car or a home improvement store go to lawn and garden and get a 3-4 mm gas line
Apr 23, 2009 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Mantis will not start
mantis tiller primer ball will not pump gas. I replaced the old one and it still does not pump fuel. when Ipump the ball Iget pressure in one line but no sucttion into the carb.
Oct 09, 2008 | Mantis 2-Cycle Tiller
Mantis Tiller Logo
444 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
