Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Electrical shock on audio video jack
On starting the TV,recently i found electrical power on the audio and video jack at the rear side of the TV. Hence when i connect my separate audio system with the above audio and video jack of the TV the audio system becomes electrified and i found electrical shock on the metal body of the audio system. Kindly help.
  • sentapaskuma May 31, 2009
    It is not the question how to protect from the electrical shock .The point is why the rear A/V jacks are getting elec.power which transfers to the separate audio system
  • 822 Answers
There is a current if you dont use is sleeper or shoes and if your hand is weat of water. its normal. be sure that your TV is not fix eversince.
Posted on May 31, 2009
I have an Apex LD4088. It has power, but has no video or audio
In fact it is dead. Just make a hard reset to it and check. Unplug the TV from AC mains wall socket and re-plug it back after 10 minutes or so. This must make it a hard reset. It this do not help you, the main power inverter board should be checked for fault. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 07, 2013 | Apex Digital LD4088 LCD TV
Nothing happening when hit power button....
If you are SURE you have hooked it up correctly, and it sounds like you have, be sure you have it plugged in a outlet that you know that works. You shiuld see the power light come on after turning it on. If it still doesnt work, you have to contact ebay or the person you bought it from for a return.If you need help dealing with Ebay please let me know, ive had to do it b4. Here are detailed instructions and the Service dept number for NES Connecting the NES Control Deck to your TV set There are two alternative methods of connecting the NES Control Deck to your TV set, depending on your type of TV: EITHER: (1) Using the Audio/Video Cable; OR: (2) Using the RF Switch and Converters. Make sure that you are not trying to use both the RF Switch and the Audio/ Video Cable: only one is required. First, compare your TV with the following illustrations (1), (2)(i) and (2) (ii) to determind which method you should use, (1) or (2). If you have a VCR connected to your TV, see below. --- (1) Using the Audio/Video Cable (Note! If your TV does not have direct audio/video connections, proceed directly to Method (2) "using the RF Switch and Converters".) Control Deck Back of TV Set (or VCR) -------------------------------------------------------------------------- Video-out jack Video-in jack --- Audio/video cable --- Audio-out jack Audio-in jack Note! Color coding of TV connections may differ from that of audio/video cable and Control Deck. Nintendo recommends against using a rear projection television with your NES as image retention on the screen may occur. To facilitate connection to video recorders, etc., many TVs have special audio/video input jacks. If your TV has such a jack, connect the audio/video cable supplied with the NES between the audio/video out jacks on the NES Control Deck and the audio/video in jacks on your TV set, and then flick the switch located on your TV that changes the TV from antenna reception to direct audio/video input. When you use the audio/video cable to connect the NES to your TV, there is no need to use the RF switch or converters, or to touch the antenna on the back of your TV. For more information on direct audio/video hookups to your TV, consult your TV Operation Manual. --- (2) Using the RF Switch and Converters (compatible with most TVs) (i) If your TV has TWO SCREWS FOR VHF antenna connection, connect the RF switch and NES as shown below. If your TV has a VHF cable connector, please see below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch -- 75/300 ohm converter -- VHF Screws --- (ii) If your TV has a VHF CABLE CONNECTOR connect the RF switch and NES as shown below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch --- VHF Cable Connector Note: if a VCR is already connected between the antenna and the VHF terminals on the back of your TV set, the RF Switch MUST be installed BETWEEN the VCR and the TV as shown below: (Refer to the illustrations above for your type of TV connection.) With this hook-up you are still able to record TV programs while using the NES. Antenna -- VHF in (From Antenna) VHF out (on VCR, to TV) -- RF Switch -- TV RF Switch -- Control Deck --- Connecting your NES Components. - Connecting the AC adapter to the control deck Insert the AC adapter power plug into the AC adapter jack on the back of the Control Deck. - Connecting the controllers to the control deck Both controllers are identical and may be connected to either controller socket. However, the controller connected to controller socket 1 becomes Controller 1, and the controller connected to controller socket 2 becomes Controller 2. The distinction is important when selecting and starting games, since only Controller 1 is used to select and start games. NOTE: Do not insert or remove controllers from control deck during gameplay as this may cause game malfunction. --- Operating your NES - To Start Play 1. Turn your television on to Channel 3. (Note: If Channel 3 is broadcasting in your area and interfering with the game, set the television and the switch on the back of the Control Deck to Channel 4.) 2. If your TV has an automatic fine tuning control (AFC), turn it off. (Use the manual fine tune dial to adjust the picture after inserting the game pak as described below.) 3. Make sure that the power switch on the Control Deck of off. Caution!! Always make sure that the power switch on the control deck is off before inserting or removing a game pak!! Always check the game pak edge connector for foreign material before inserting the game pak into the control deck!! 4. Open the Chamber Lid on the Control Deck. Insert a Game Pak into the Chamber (label facing up) and push it all the way in. Press down on the Game Pak until it locks into place and close the Chamber Lid. 5. Turn on the power switch of the NES Control Deck and push the reset button. Note: If the "reinsert" indicator light on the front of the Control Deck is flashing, it means that the game pak is not loaded correctly. In this case, turn off the Control Deck power switch and start over from step 4. Note: When the game pak is inserted properly, a colorful game display should appear on the TV screen. If it does not, or the picture is imperfect, turn the Control Deck power switch off and then on again, and press the reset button. 6. Use the Select button on Controller 1 to select the game you want to play, and start the game with the Start button on Controller 1. Note: If you experience any problems in operating your NES, please do not hesitate to call Nintendo's Consumer Service Department, toll free, at 1-800-422-2602.
Sep 17, 2007 | Nintendo NES Console
Where do I plug in headphones?
Looking at the specs for your TV, it does not appear to have the jack for earphones.
You will have to connect an audio receiver to your TV and use the reciever's jack.
Connectivity
  • HDMI ports qty4
  • PC interfaceVGA (HD-15)
  • Input/Output connections3 x HDMI (19 pin HDMI Type A) - Rear,
    1 x HDMI (19 pin HDMI Type A) - Side,
    2 x Component video input (RCA phono x 3) - Rear,
    1 x Composite video/audio input (RCA phono x 3) - Side,
    2 x USB (4 pin USB Type A) - Side,
    1 x Ethernet (RJ-45) - Rear,
    2 x Audio line-in (RCA phono x 2) - Rear,
    1 x VGA input (15 pin HD D-Sub (HD-15)) - Rear
  • Video interfaceHDMI,
    Component,
    Composite
Jul 14, 2012 | Samsung PN50B650 50-Inch 1080p Plasma HDTV
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
Can't get my Proview TV to recognize the signal
Good day!
Please check the connection of the jack from your TV to DVD.
Follow this step on how to connect the AV (audio and video) jack.
  • For the DVD connection.
  1. Find out where is the video out of the DVD.It is usually have a label (video out) and the color is yellow.
  2. After that,connect the jack (color yellow) to the video out of the DVD.
  3. Next,find out where is the audio left and right out of the DVD.It is commonly have a label (rear,front and center) choose 1 of the location you want.also it have a standard color (red and white)
  4. After that,connect the AV jack(red and white)to the audio out of the DVD.
  • For the TV connection.
  1. Find out where is the video IN on the rear side of the TV.It is usually have a label (video in) and the color is yellow.
  2. After that,connect the jack (color yellow) to the video IN of the TV.
  3. Next,find out where is the audio left and right IN of the TV.It is commonly have a label (audio in ) and found in the rear side of the TV.also it have a standard color (red and white).
After you connect the AV (audio/video) jack.Try to open the TV and the DVD and set your TV to the AV mode by pressing the AV label on the remote or on the TV button.
If the video is not appear on the AV1 try AV2 ,AV3 and so on.Or also try other AV on the TV.
I hope this solution will be helpful.Thank you and good luck.
May 06, 2011 | Televison & Video
Need to locae he audio outputjcks on my 32 in LG
Here is the list from the spec. sheet of all of the connections available on your TV
1.0 x HDMI ( RCA phono x 3 ) - Rear , 1.0 x Composite video/audio output ( RCA phono x 3 ) - Rear , 1.0 x VGA input ( RCA phono x 2 ) - Rear , 1.0 x Remote control ( 4 pin mini-DIN ) - Rear , 1.0 x S-Video input ( 19 pin HDMI Type A ) - Rear , 1.0 x Serial ( 4 pin mini-DIN ) - Rear , 1.0 x Composite video/audio input ( RCA phono x 3 ) - Rear , 2.0 x Composite video/audio input ( Mini-phone stereo 3.5 mm ) - Side , 1.0 x Audio line-in ( 15 pin HD D-Sub (HD-15) ) - Rear , 1.0 x S-Video input ( RCA phono x 3 ) - Side , 1.0 x Audio line-in ( TOSLINK ) - Rear , 2.0 x Digital audio output (optical) ( 9 pin D-Sub ) - Rear , 1.0 x HD component input - Rear
Nov 20, 2009 | LG 42LC2D 42 in. LCD HDTV
Do I have any options to get 'audio out' instead of h/p jack?
Try the Audio 1 rear. With the headphones plugged in on some T.V.s the headphone jack unfortunately disconnects the audio from the other outputs. Try looking in the documentation to see if you can change this in the T.V.s menu as some allow you to use both for hearing impaired people. Hope this helps.,
Jul 09, 2009 | Sennheiser RS 120 Consumer Headphones
Tv magnovox tv
firstly try that tv to a different tv
if this works
then check your tv av connections in side tv
also check cables continuity
if this fails buy a AV/ RF converter, have your AV be connected to a converter, and let your output be RF feed to a tv, RF input, so instead of using AV on your tv you will be using RFchannel mode
Mar 16, 2009 | Philips Magnavox 27MS343S 27" TV
I recently purchased an xbox, but because of the cable box, i dont know to to get video
Your cable box and TV should have RCA input jacks (Red, White, and Yellow) Red & White are for Audio and Yellow is for video feed...
HD Receivers & HD TV's are just slightly more upgraded with better video feed connections.
HD video can use three color coded RCA jacks for the video feed or a HDMI cable; if you can use the HDMI connection on your TV I recommend using that because it's less confusing to plugin the input cables. Try turning your TV to it's side to see what inputs you have available to connect your device to.
After you have it pugged your device into the input jacks press the "Input" key on your TV remote and power up the device.
Most TV's have more than one input, so you may have to cycle through the TV inputs by press the input key again until the video feed is displayed.
(If you don't have a "input" button on the TV or remote control you can try entering channel "00")
Nov 28, 2008 | RCA T09081 9 in. TV/VCR Combo
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
