Question about Kenmore Dishwashers
My Kenmore 363 dishwasher has not been used in quite a while and will only hum when turned on, no water. what can I do to get it working again.
My kenmore 363 dishwasher has not been used for quite a while and does not do anything but hum when turned on???? What can I do to fix it and make it work??
  • gmalone9 Jun 01, 2009
    is it possible that the valve is frozen up and not letting water in, therefore no cation??
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 117 Answers
Hello There
If your dishwasher was working perfectly before this incident and all that has happened is no use, then the problem is with the motor. It's most likely some gunk/dirt has dried up over time and is preventing the motor from turning. The humming sound suggests the motor is trying to turn but is stuck. your motor and the assembly should look similar to this.
http://www.repairclinic.com/SSPartDetail.aspx?PartID=1060514&PPStack=1
When you will need to do is take out the motor and the assembly from the washer and thoroughly clean the motor with some soapy water, you will have to seprrate the motor from the assembly to do this correctly, once the motor and the assembly are clean, you will need to apply lots of WD40 on both of them, try to turn the motor and keep appling WD40 until the motor starts to turn freely, clean and wipe with a dry cloth, leave it out for a few hours then reassemble and put back into the washer, this will resolve your problem, there may still be some humming noise but I'm afraid thats common to all Kenmore's.
I hope this helps and please don't forget to rate me.
Many Thanks
Posted on Jun 01, 2009
  • ILikeBMW
    ILikeBMW Jun 01, 2009
    Hello There
    Yes thats is a possibilty however the pressure at which the water is pumped wil normally clear this, but the problem is dried gunk/dirt in the system, when you clean the motor and assembly it's worth looking at doing a through clean all round.
    Hope this helps.
    Many Thanks
Dishwater in bottom of dishwasher
You need to mount the drain hose up; i.e have a portion of it that is higher than the bottom of your sink so water can't backwash into the dishwasher. Although most (all?) dishwashers have a check valve that is supposed to stop this, sometimes, after years of use, that check-valve doesn't work 100%, and water can leak by it. By mounting the drain hose up, it will help prevent this problem.
Sep 17, 2014 | Kenmore Dishwashers
Kenmore 3/4 hp garbage disposer does not work, it only hums.
Do not turn on... humming sound will overheat motor
See if cutter disc located inside disposal can be moved and rotated using broom stick:
If disc rotates freely, then try motor again... if still hums, then replace disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene h
Mar 25, 2014 | Kenmore 3/4 hp Food Waste Disposer
Turn dishwasher on . the water loads in and then goes into wash cycle, it does it's wash cycle then drains and will not load clean water for rinse cycle it just hums a and then quits, then tries again and...
Tim Derbowka, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Tim Derbowka), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool GU2300XTS 24 in Builtin...
I bougt a kenmore 18" dishwasher, the dishwasher
Sounds like the water is either off or a flood safe hose is being used. The valve is energized and water is not flowing in, that is what the humming noise is.
Appliance & Refrigerator Repair
Mar 22, 2011 | Kenmore 18 in. 14432 / 14439 Built-in...
My Kenmore Elite dishwasher just hums when we start it.Its not starting and no water is filling up
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Aug 09, 2010 | Kenmore Dishwashers
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 | Dishwashers
Kenmore dishwasher.not working
I decided to buy a new dishwasher! The motor was making a humming noise after the water filled, and there was a burning smell, so I decided to replace the dishwasher!!
Oct 24, 2009 | Kenmore Dishwashers
My Kenmore dishwasher model 363-1404596 does not clean the dishes completely
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film.(Disregard if this is not an issue)
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Oct 16, 2009 | Kenmore Dishwashers
My Kenmore elite dishwasher not working, the green light under ''clean'' is flasher , can you help? thanks
My Magic Chef dishwasher is humming when I turn it on. Then when I force it to the next setting where the water turns on it still hums. I am afraid of it burning the motor so I just stopped it. What could the problem be?
Jul 10, 2009 | Kenmore Dishwashers
Dishwashers Logo
191 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
