Question about JVC HD-52G786 52" Rear Projection HDTV
JVC HD-52G886 IN REAR PROJECTION SCREEN
When i turn in on the power light turns on blue for a min. But the tv wont turn on. The lamp program light blinks red three or four times. I bought a new lamp and installed it but that didnt fix the problem can anyone help thanks. I have exactly the same problem with my TV. Same make and model. Changed the bulb. Did not fix. The "power" light comes on briefly, and then the "Program/Lamp" light starts to blink. Last time this happened it just needed a new bulb. Not this time. Could it be something to do with the cooling fan?
SOURCE: hd 52g886
Your Lamp is burned out.
Posted on Sep 07, 2007
Slinteriors
  • 8617 Answers
SOURCE: replacement lamp
www.alltvlamps.com should have the lamp your needing
Posted on May 18, 2008
SOURCE: jvc tv
when both the blue light and red light are blinking it means 1 of 3 things. 1. lamp replacement. This often works everytime for the repair. TIP!!! DO NOT USE ANY OTHER LAMPS OTHER THAN JVC AUTHENTIC LAMPS. ANY OTHERS AND YOU RISK DAMAGING YOUR TV FURTHER. 2. the fans are not working properly or need to be replaced. They need to be cleaned every so often and they will stop working from burn-out if not done so. This repair will cost you less than 100 dollars. 3. The ballasts are defective and need to be replaced. The ballasts themselves run about 150 dollars. I tell you I have fixed this TV more times than I care to count, not to mention the number of lamps I have gone through. The guy at the TV repair place now knows me by name when i come to buy lamps. :(
Posted on Dec 07, 2008
fieldy14
  • 456 Answers
SOURCE: rapid blinking light (lamp) on a JVC model HD
It normally means the lamp is in need of being replaced, and its all depending on the use of the TV as well as how long the lamp life is. You should be able to access the lamp via a small section near the rear or the back of the TV unit, if the lamp is blown or faulty it will look the same as a blown light globe.
To obtain a new lamp contact the brands authorised repair agent as they will be able to get trade prices and in turn, give you the best price,
Also make sure that whoever replaces the lamp resets the lamp use time as the TV will still not start if you don't reset the lamp use time as it will still think it has a faulty lamp. I hope this helps, good luck.
Posted on Dec 05, 2009
tomswrldtech
  • 90 Answers
SOURCE: where is the projection lamp
hi there, I'm sure you can find it at the back casing fronting the screen. It has this box casing and you can see a glass prism. I also insert an image of JVC lamp. hope this help, please rate and vote
Posted on Mar 20, 2011
I put a new bulb in my jvc tv and it still blinks red why
take it out and put it back in it may have been put in wrong or something
Apr 05, 2013 | JVC HD-52G886 52" Rear Projection HDTV
Jvc hd-52g886 wont turn on
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Feb 23, 2012 | JVC HD-52G886 52" Rear Projection HDTV
TV won't turn on - the front blue power light and red lamp light blink. Does this mean the lamp needs to be replaced?
Yes.The tv projection lamp inside the tv right now it is been inside the tv like a 1 1/2 or 2 years already.The tv been on daily and in used like 4 or 5 hrs tv watching daily?Yes,than the tv projection lamp life are ending and the causes.
May 08, 2011 | JVC HD-52G886 52" Rear Projection HDTV
When i turn power on the power light comes on but no picture the lamp light comes on then starts blinking?
The tv projection lamp has not been replaced in this tv like 1 1/2 or 2 years?The tv been on an watches tv like 4 or 5 hours a day?Yes,than the projection lamp life is over.The tv require a new projection lamp.
Oct 12, 2010 | JVC HD-52G886 52" Rear Projection HDTV
How do i reset my jvc tv
Either a bad lamp or bad reciver board.If audio amp ic on reciver board shorts ,it will kill part of supply and lamp ballast will not turn on and fire lamp.
Dec 28, 2008 | JVC HD-52G886 52" Rear Projection HDTV
TV not turning on
This is the lamp error code. The lamp part# for your unit is
TS-CL110U. Hope this Helps.
Mar 21, 2008 | JVC HD-52G886 52" Rear Projection HDTV
JVC AV56WP74
Replace the lamp, also the shut down time is correct the unit must allow plenty of time proper lamp cooling. otherwise the lamp life will be greatly shortend. normal lamp life is 3000 hrs.
lamp replacement may require an internal limp timer reset have a qualified tech replace the lamp.
Oct 06, 2007 | JVC HD-52G886 52" Rear Projection HDTV
Hd 52g886
Sep 04, 2007 | JVC HD-52G886 52" Rear Projection HDTV
JVC HD-52G786 52" Rear Projection HDTV Logo
102 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
