Question about Vehicle Parts & Accessories
The imoblelizer is on
I have a 2007 Toyota Tacoma. I have put in new fog lights, wired in with the mirrors for power. The truck will not start now. It turns over and that is it. The alarm will not engage/disengage now, and the imobilizer seems to be on. We also found a button in the ashtray spot (or what should be the ashtray,it is just a compartment) and have now pressed it a bunch, I don't know if it is for the alarm. Any help?
  • 87 Answers
Have you tried to disconnect the negative from the battery? If not do that and the positive cable. With both disconnected touch them for 15 seconds; that will drain any remaining power in the system and hopefully reset the system. If not then it may have an aftermarket alarm system that needs to be unistalled and or fixed.
Posted on Jun 02, 2009
Getting b1650 code on 2007 toyota tacoma, already had the recall on the airbags fixed, and light is still on with that code. how they said it was somethig with seat or floor wire? how do i check the...
Hi Jig, I suggest you take the vehicle back to the same center where the recall was carried out, as it seems to me that something was not done correctly. Regards John
Jan 18, 2013 | 2007 Toyota Tacoma
2007 Toyota Tacoma air bag light came on and radio stopped working...
Have you tried replacing fuses? i would look there first. a blown fuse is easy to see.
Jul 27, 2012 | 2007 Toyota Tacoma Access
I own a 2006 tacoma. Fog lights were installed by Toyota when purchased. The fog light indicator light on the dash board no longer lights. I brought it to Toyota and they said the truck doesn't have...
As with many of these questions, a look through the owner's manual is a place to start. I have a Hyundai, and though it does not have fog lights there is a page in the manual showing what the dash
looks like if the car is so equipped and not so eqiupped. Same as on my Subaru, which does have fog lights. The manual shows the dashboard with and without that option. If this was something available as an option, but they put it on after sale then they most likely used the Toyota wiring harness which is ready to go either way, and the pop out plug in the dash for the switch/light so it should be pictured in the manual. If it is a total aftermarket kit then you have nothing to go on unless you take it to the dealer where it was done and ask them to look up their records, it is only 4 years old.
Dec 30, 2010 | 2006 Toyota Tacoma
How to fix compass of toyota tacoma 2007. it just
Are your cruise control, dome, and tail lights also out? If so then it is a fuse. If not then the control unit has gone bad internally. You may be able to get it fixed under your warranty.
If it is not covered by your warranty, check out
www.autoclockrepair.com. We offer a very reasonable repair solution.
Feb 24, 2010 | 2007 Toyota Tacoma
I need instructions on how to replace my driver's side power mirror on my 2007 Toyota Tacoma truck.The cowling is broken although the mirror still rotates. There is an access screw on the bottom of the...
Pull off the triangle shaped cover on the inside of the door panel over the mirror area by prying it off.
Remove the three 10mm nuts behind the cover, unplug the connector and slide the mirror off the door.
Oct 22, 2009 | 2007 Toyota Tacoma
2001 Toyota Tacoma Engine Miss
Start with the plug wires.You may need new plugs but my experiance is that the plug wires are the first to go.
Oct 20, 2009 | 1999 Toyota Tacoma PreRunner
No dome light on tacoma
The dome light gets 12 volt battery power at all times. The door switch, when the door is opened, allows the current to flow to ground, and completes the circuit. The door switch allows the ground to be made. Measure for 12 volts at the wiring connector, and measure for direct short at the ground wire, with the door open. The Ground wire is white with a black tracer.
Feb 26, 2009 | 2004 Toyota Tacoma
2007 Tacoma Tail light problem.
Check the taillamp fuse on the truck. If it is blown, you either have a short in the wiring of the camper, or the 7 pin inverter box on the camper.
Oct 27, 2008 | 2007 Toyota Tacoma
Vehicle Parts & Accessories Logo
77 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
