Question about Kenmore Washing Machines
Ont stop filling with cold water
My kenmore 90 series top loader wont stop filling with cold water
  • 6,784 Answers
Hi. the pressure sensors in the water valve assembly appear to be damaged. you will need to replace the inlet water valve assembly in this case asap.
This is solenoid failuer. (basic water valve failure this case)
Posted on May 31, 2009
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My kenmore 90 series filled with water and went it got to the rinse cycle it quit working and just started making a grindling sound. help please
sounds like the motor coupler broke. it's a plastic piece near the motor and very easy to replace.
here'e a video you can watch to make it easier:
http://www.youtube.com/watch?v=nM4DW2bq7o0
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Kenmore washer 90 series will not fill up with water
You can shut off the water, then remove the hoses to see if the screens on the fill valve are gunked up. This is much easier to do than to replace the valve. I think you'll have sucess on that route :)
Aug 09, 2009 | Kenmore Washing Machines
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
Will not fill with water goes right down the drain,works sometimes
Your drain line is too low or there is a air gap blockage.
Remove the drain line from the drain and hold it up high while filling with water and see if it fills and stops.
If so, correct the drain line problem.The drain hose should be 36 inches from the floor.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
My kenmore 70 series wont stop filling with cold water. the hot water stops filling.
you need to replace the water inlet valve on back of washer as the cold water side is not opening,it's easy,remove the 2 top head screws,flip the head up,use a screw driver to pop the 2 clips out(1 on each side top),unplug the wire jack,now pull the back,back so you can get to the valve-mike
Mar 21, 2009 | Kenmore Washing Machines
Kenmore 90 series Water pressure turning up and down
it will switch from hot to cold and back and forth trying to regulate the temp. You probrbly have more pressure in your cold water line than your hot or vise versa. This will cause it to seem to pulse. Dave www.washermd.com
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series Clothes washer
there are filters in the fill hose which could be blocked but usually the fault is low water pressure
Aug 31, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series top loader the washer will not fill with cold water only hot water
Yes patrick you can try removing the cold hose from the washer, look inside the valve for a metal screen. If it has sediment blocking it remove screen, clean it and reinstall. If still no water replace inlet valve.
Dec 01, 2007 | Kenmore 24902 Top Load Washer
Washing Machines Logo
160 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
