PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Need help
By zackie on Oct 23, 2007
When ever I turn on my computer, all i see is disk read error occur. Along with it is how to restart it, but when i tried to restart it, the same thing comes back
Same Problem
May 11, 2008
-   I get a double beep during startup.. says Fixed Disk Error 0... then it sais F1 to continue and F2 to go to bios.... IF I hit F1 it goes to black screen and flashes Family Fast Ethernet adapter failed..... then goes blank and pops up again over and over and over... If I go to bios I can get right into bios with np.... Solutions we have done so far were to order the restoration disks... Replaced (UPGRADED) Memory and bought a new HD Neither of these have changed the situation.. I have done a full system restore about ten times. It works for about 35-60 mins after it is restored but then I get the Blue Screen saying that computer must reboot due to Memory Dump. Then It wont boot back again it goes into the F1 F2 choices again.... Im stumped!!!!!!!!-   giventake
Solution #1
posted on Jan 07, 2008
Not Rated)
Nitrotrike
Rank: Guru
Rating: 88%, 840 votes
It may be a corrupt MBR, or possibly the boot partition. If you have an XP disk, try to get into the recovery console.
1. Restart your computer with the Windows XP Setup disk in the CDROM drive.
2. If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive.
3. After a few minutes, you'll see a prompt to press the R key to start the Recovery Console.
4. When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases, you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer.
5. Enter your Administrator password (if you have one) If you don't enter the correct password, you cannot continue.
6. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed.
If that doesn't work, try the above procedure again, but substitute "fixmbr" with "fixboot". Good luck!
Was this helpful?
Yes
No
Solution #2
posted on Oct 23, 2007
Not Rated)
KatFishGR
Rank: Guru
Rating: 89%, 109 votes
Sounds like a failing hard drive or corrupt file system.
Or possibly you have a non bootable disk in the floppy drive, assuming it has one as most laptops dont.
Is this Windows XP? If so, try booting from the XP cd. At the menu, choose R for recovery console.
In the recovery console, type in CHKDSK /R and let it run, it may take well over and hour to run, if it runs at all. If the recovery console is unable to load, or chkdsk wont run, you may have a failing hard drive.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
How to apply this layout on my account?
Answer
i want to bye the best performance laptop on the market, with the state of the art hardware, 15in... (More)
Answer
So really nothing works for this blank screen problem? I ahve a HP dv9000. I have tried the remove... (More)
Answer
The display of my HP Pavilion dv8220us no longer works. It has lines of color in it, but no display.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , CA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
