Question about Texas Instruments TI-83 Plus Calculator
Cannot calclate sin cos tan with texas inst ti-83 plus
Cant put it in scientifc mode...how do I do it??
  • 13 Answers
To put it in Scientific mode, press MODE then use your right arrow to move your cursor one spot to SCI. Press ENTER then press CLEAR.
Posted on Jun 16, 2009
Sin cos tan ti 83
Make sure you have the proper angle mode set. Press MODE and check the third line.
Feb 03, 2014 | Texas Instruments TI-83 Plus Calculator
How do i work out the Sin, Cos, and Tan on the TI-83 plus?
First, make sure you have the appropriate angular mode set. To change the angular mode, press MODE, use the arrow keys to highlight either "RADIAN" or "DEGREE" on the third line, press ENTER, then press 2ND [QUIT].
Press the appropriate sin, cos, or tan key (two rows above the 7, 8, and 9 keys), enter the angle, close the parenthesis, and press ENTER. For example, to calculate the sin of 2.1, press
SIN 2 . 1 ) ENTER
Jun 07, 2011 | Texas Instruments TI-83 Plus Calculator
I dont know how to enter in a degree and get its COS, TAN, SIN ect.. Can anyone help me out with this.
Press the SIN, COS, or TAN key, type in the angle, and press ENTER. For example, to calculate the sine of 45 degrees, press SIN 4 5 ENTER
Make sure you have the angular mode set to degrees. It's the third line on the mode screen, which you get by pressing the MODE key.
Jan 30, 2011 | Texas Instruments TI-84 Plus Silver...
Sin, cos, and tan do not seem to work properly.
Press "Mode" Check to see if you are in radian mode or degree mode (one of the top categories)
If you are entering your numbers from sin, cos, and tan as degrees and you are in radians, your answers will be off. Same goes for if you are inputting radians while in degree mode. Hope this helps
Dec 26, 2010 | Texas Instruments TI-83 Plus Calculator
I have a TI-84 Plus Silver Edition calculator and I need to find the inverse key to get values for sin, cos, tan, csc, sec, cot. I'm past the lesson where you use the 2nd/sin, cos tan to find the...
There are no keys for cosecant, secant, and cotangent. You can calculate those ratios as
csc(x) = 1/sin(x)
sec(x) = 1/cos(x)
cot(x) = 1/tan(x)
Simply calculate the trig ratio on the right and then take its reciprocal.
Dec 14, 2010 | Texas Instruments TI-83 Plus Calculator
Whenever i put in sin or cos or tan on my calculator the wrong answer comes up, how do i fix this?
Most likely you do have the calculator in radians (or if you are working in radians, you have it in degrees). Press the mode button, move cruser down to "radians degrees" highlight degrees. and press "2nd quit". things sould be better!
Jun 03, 2010 | Texas Instruments TI-83 Plus Calculator
Need to know how to obtain the cot,csc, and see in the degree mode and radian mode
There are no dedicated keys for these trigonometric functions, for the simple reason that they can be obtained from the tan, sin, and cos by a simple division.
cotangent (x) =1/tan(x) . Do not confuse with the arc tangent tan^(-1)
cosecant (x) = 1/sin(x) . Do not confuse with the arcsine sin^(-1)
secant(x) =1/cos(x) Do not confuse with the arccosine cos^(-10)
If you know how to use the tan, cos, and sin, with angle unit in degrees or radians, then there will not be any problem
If angle unit is degree, any number you give a trigonometric function is interpreted as degree. For instance if mode is in degree , and you calculate cos(PI) do not expect the value -1. You will have the value corresponding to the cosine of of 3.14159 degrees, namely 0.99849715
Now for you if you are interested.
If [MODE] is in degrees you can still enter angles in radians
You use the [2nd][ANGLE] [3: raised r] [ENTeR].
Here is a screen capture to show you more clearly.
The raised r is obtained by [2nd][ANGLE][3: raised r] [ENTER]
Hope it helps.
Oct 13, 2009 | Texas Instruments TI-83 Plus Calculator
Tan Cos and Sin errors
go to:
mode
select DEGREE rather than RADIAN three lines down.
Aug 20, 2008 | Texas Instruments TI-84 Plus Silver...
TI-84 Plus silver edition sin/cos/tan
for function = (sin,cos,tan,sec,cosec,cotan)
arc(function) = function^-1, calculated in the first quadrant for simplicity(0-pi/2) (0-90deg), as all functions repeat circularly
just another method of notation
http://www.mathwords.com/t/tangent_inverse.htm
Jun 19, 2008 | Texas Instruments TI-84 Plus Silver...
Need help withe the sin, cos, tan problem with ti - 83 plus
here are the steps in changing it from radian to degrees
1. turn on your TI-83 plus
2. press the MODE button near the top of your calculator
3.go down to options and move the highlight from radian to degree, press enter and clear
you're good to go
Feb 17, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
463 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
