Question about Crosley 40-pint Dehumidifier
Crosley Dehumidifier won't run... has not been used much
My Crosley CMF-40 will not run. It says power is, full switch is open, motor (fan) "clicks" with power... but does not run. Can you help me?
  • Crosley Master
  • 43,501 Answers
Here is a tip that I wrote to help people with just that dehumidifier problem..
DehumidifierCrosley Dehumidifier won't run... has not been use - 2_bing.gif Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Posted on May 17, 2010
Crosley conservator dehumidifier will not capture humidity
Have you noticed it not running as often or not being noisy? Also have you tried to select a continuous drain setting if your unit has one?
Aug 14, 2012 | Crosley W.C. Woods DCW40S Electric...
It does run yet won"t heat up!!
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 08, 2011 | Crosley DCW25-1 Dehumidifier
Need float switch that cuts off dehumidifer when bucket gets full
Without a Model Number or Part Number it's hard to help you. But here are three links, where you can find the float switch, if it's still available. You'll definitely need the Model Number to find anything.
http://www.apwagner.com/index.php?main_page=page&id=148
http://www.appliancepartspros.com/crosley-dehumidifier-parts.aspx
http://www.partselect.com/Entry.aspx?Source=GAWS&Brand=Crosley&Term=crosley+dehumidifier+parts&gclid=CIzJ3ZvR4KgCFcV95Qodnh3C0g
Hope this helepd you. Please let me know. Thanks.
May 11, 2011 | Crosley 40-pint Dehumidifier
The fan runs but the compressor will not start
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Mar 24, 2011 | Crosley 40-pint Dehumidifier
Crosley dehumidifier does not collect water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 13, 2010 | Crosley 40-pint Dehumidifier
I have dh404ey7 dehumidifier from goldstar and the fan wont turn on how do i get to work without spending alot of money?? Thank you
No there is no way to lubricate the fans internally...they are made to run for a bit and then be thrown out...
I have found that by using a thin oil like WD-40 and then positioning the motor so that it runs back the shaft into the motor you can get it to work into the motor. I usually use WD-40 and then follow with a light motor or sewing machine oil. This seems to give a longer solution...
heatman101
Asker's Testimonial " Just the advice that I expected, and what I had already performed Dehumidifier is running but no water is in bucket
May 06, 2010 | Goldstar DH4010B Dehumidifier
Crosley dcw25-1 about 3 yrs old, moderate use,
heatman101
Aug 02, 2009 | Crosley DCW25-1 Dehumidifier
Compressor won't kick in
heatman101
Jun 14, 2009 | Crosley W.C. Woods MCR40ES Electric...
Dehumidifer - Working??? Not Sure.
if you can verify that the compressor is still active (is there a noticeable hum or buzz and / or do the room lights slightly dim during power on?) then the most likely problem is a loss of freon. if the compressor never turns on, then a faulty humidistat is likely...an electrician can run a test of this by "jumpering it out" to force on the compressor motor.
May 20, 2007 | Crosley 40-pint Dehumidifier
Collecting no water
My crosley dehum. acted the same way. It turned out to be a bad defrost thermostat on the evaporator coil.
May 14, 2007 | Crosley 40-pint Dehumidifier
Open Questions:
Crosley 40-pint Dehumidifier Logo
139 people viewed this question
Top Crosley Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Crosley Dehumidifier Expert? Answer questions, earn points and help others
