Question about Coleman Campers Grill
The air conditioner on my pop up camper is loud and vibrating
The unit is blowing cold air. But the camper is shaking and the noise is awful. What can I do ?
    Champion:
  • 225 Answers
Sounds like the compressor in your air conditioner has a broken spring in it,you can not take the compressor apart to fix,has to be replaced(cashy).I assume your camper is shaking,and the noise only happens when you turn on the air.
Posted on Jun 13, 2009
Loud air conditioner on 2017 Guld Stream 188rb Conquest
You need to get on to of your camper and remove the cover, typically a few larger screws and maybe washers will secure the housing cover; (is: the AC's on my unit has 3)
1. Check for any foreign objects between A/C (air conditioning) fan and cooling radiator, producing this loud noise. It is not uncommon for a small animal to have gotten on top of your camper and made its way inside the housing, especially if it has been in storage.
2. Look to see if you have any damaged or missing can blades. If material is missing, the balance could be off causing vibrations. It would also be a good idea to see if any hardware is loose and only needing to be tightened.
3. Having a person to assist, have that person turn on the AC and listen for a loud noise comming from the fan's electrical motor. Like any regular electric motor, bearings can wear out and squealing or other noises will be hear before it finally stops completely.
4. It the unit is not cooling enough of not getting as cold as it once did, you may need to get the coolant recharge, typically an authorized HVAC tech can do that.
5. If the AC is not blowing any cold air at all, most likely the part that is bad (cannot recall exact name right now) is like a coil; black, round, a little bigger then a quarter in diameter and a couple inches long with a couple wires on it. If you have a manual with a diagram, you may be able to locate that part.
Above all else, if there are compounded issues going on, you may want to consider a replacement instead of buying several various parts, depending on the age of the AC you have right now. It may cost a little more but a new one will come with a warranty and be more efficient.
Apr 14, 2017 | RVs
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
My AC is extremely loud and vibrates the entire house. Is it supposed to do this. I have 4 other ACs in my house and none of them do this. Sometimes the fan blows and that's fine but then it charges and...
no its not suppose to do this,the pump has a broken spring in side it which creates the viberation,unfortunatly the pump is a sealed unit so it can not be repaired.you have to replace the pump,cashie,probably be cheaper depending on age of unit to buy another a c unit.
May 02, 2010 | LG LW7000R Air Conditioner
I have a 13,500 btu coleman on our 1989 avion camper. It was making a very loud noise for some time, and vibrating then the motor locked up on it. My husband thinks the blower went out on it. It was...
You should be able to turn the fan motor freely by hand. If there is any resistance or the noise turning it by hand, then the fan motor is definitely bad. Is it a wall thermostat unit or manual controls? Wall thermostat, you can use a jumper wire from the 12+ terminal of the thermostat to the HG terminal and the fan should come on, if not, then the motor is bad.
Jun 24, 2009 | Coleman Mach III Air Conditioner
AC unit on Viking popup is loud and vibrating
take the cover off the front of unit and look down inside at the blower wheel see if there is something in it
Jan 22, 2009 | Dometic Rooftop RV Air Conditioner
My Carrier 58dxc is making a loud noise
If your turning on heat and the unit is knocking and blowing cold air, your compressor is having problems in heat mode, could be reversing valve. A tech is needed in your situation. Getting the prob fixed right away will save you dollars..
Dec 02, 2008 | Heating & Cooling
Hi. Just bought a new in box "LP" LWHD 1200R window air conditioner. When I went to turn it on, I got an awful loud fluttering noise coming from the front of the unit. NOT the "slinger...
Hello Eric,
Let me see if this will be of any help take the front cover off and check to see if any packing material has fallen down in the air baffle. this will be towards the top of the unit on the inside. Also check to make sure that any insulation seems to be in place.
May 27, 2008 | LG Heating & Cooling
Coleman Campers Grill Logo
514 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
