Question about Kenmore Refrigerators
Water coming out of the ice maker and spreading thru out
Have a Kenmore Elite top-mount refrigerator with an ice maker in the freezer. Water is coming out of the ice machine when it fills. I have already placed the proper the water tube extension pipe onto it in January and turned the temp up from 5 to 3.5 for both compartments. It was at set at 5 because of thawing of items. With the water coming out the drain pipe now freezes, water in the freezer base freezes and what ever gets into the fridge compartment 1/2 of it freezes. I am looking for next step and not buying new one as answer having enough problems here and not money wise. Inside there is a production date of 02-01, serial no el0620855 and model #10670202991. The unit is in a corner but it is an open corner and the top is clear, only the back and the right side are next to the wall with 3" clearance.
PS have posted this but to the community and never saw it go up about 3hrs ago now its your turn. Hope it gets to you.
  • 5 more comments
  • britus46 May 31, 2009
    Question is where is this screen. I have a large filter on the water line between the copper pipe and the fridge. I know items do get through and the water is lovely here in Pittsburgh. Don't know if you can see the comment before yours. We do have cats in the house need to see if that has any affect but I have kept it vacuumed out under it since this has started. Where can I get a copy of the location of these screens to check them.
    Showing me a screen that is at the bottom of the refrigerator. The ice machine is at the top.
    We do have pets in the house and there is a Kenmore Flow Cartridge (PN42 38447)that does get changed placed on the water line for the ice machine from the water line that it is attached to.
    OK if that is all that is required then why did one say to get that tube water tube extension and how come it freezes going down the drain pipe. The person back in January that told me to get this extension said that water got out from the spray of the water. But this makes more sense from the amount of water that is getting out. Question still stands though why the freezing in the drain pipe down the back of the fridge.
    After replying the first time to you I went to the unit and took the cover off. By the way its the fan unit for the ice maker and looked for this screw. Where is it and which direction is to the negative. Being an architect I know sometimes it is clockwise and not counter clock not to sound like a smarta-- sorry.
  • britus46 Jun 01, 2009
    Item #19 there is a diagram but nothing stating what each number is for. I did look at it yesterday (Sunday) and didn't see a + or - that is why I am asking. Just want to make sure I alter the correct item.
  • britus46 Jun 02, 2009
    Thanks for the help. I just have to get a chance to look at everything now and get the ice out of the drain pipe to the pan underside of the refridgerator.
  • 3,267 Answers
Since you seem to have located the problem wit help from our experts and narrowed it down to the connection details, the general thumb rule for color coding is ---------that Blue is ground, Red is live(-ve) and Black/white/green are for neutral(+ve). Also check the solenoid of the water filling assembly and replace the solenoid which controls the flow of water into the ice maker. Also ckeck if any warning LED is lighted up. The problem might just be on the sensor which senses the amount of water level in the icemaker which having malfunctioned is responsoble for water overflow in the icemaker otherwise there would be no excess water which is not supposed to be present if the sensor is working properly!
This is is my intutive deduction as a Mechanical Eng. and consider this as an suggestion/pointer/advice(personal) regarding your problem since so many experts have already given their advice/solution .............................................................sodeep
Posted on Jun 02, 2009
    President:
  • 2,559 Answers
If the problem is just the water is overflowing when the ice maker fill,Just remove the front cover on the ice maker and turn the ice size screw towards the negative symbol (-) this will adjust the fill level.
Once the water fill level is correct the ice in the bottom will stop being produced.
Posted on May 31, 2009
  • Randy Hough
    Randy Hough Jun 01, 2009
    It is located behind the fan,Negative is counter clockwise and the screw will be marked with negative and positive symbols here is a link to the diagram
    Brigadier General:
  • 3,614 Answers
First check the unit valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere.
Let me know
  • 136 Answers
I have a feeling that its an issue with the defrost... i know you said you dont want to have to get a new fridge but i would reccomend that you get it checked out. you should also pay close attention to that ice maker... the filoter is clean right?
KENMORE ELITE TOP MOUNT #2218591. I have to keep 2 bowls in the back of the refrigerator on the top shelf beacause water is leaking from somewhere. It has an ice maker. Could that be the problem?
this is a a frozen drain . kenmore has a drain heater kit the will correct the problem .. very common with top mount freezers .. .. hope this helps mmm feed back pls /
Jul 09, 2011 | Kenmore Refrigerators
Kenmore Elite top mount refrigerator getting ice on top shelf and watr accumulating on bottom and in vegetable drawer. I cleaned the freezer and unblocked clogged ice but it still is a problem.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 20, 2010 | Kenmore 21.7 cu. ft. Top Mount...
Icemaker not working on a Kenmore Bottom Freezer
if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
Dec 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dead fish smell from my Kenmore Elite Bottom Mount Refrigerator
dead fish smell ( under the frig there is a cond pan that collects water from the defrost . whirlpool has some tabs that you can put in pan/ it helps .. I would put a cup of bleach in pan every 3 months . and if you can find the drain inside the freezer add it thorugh the drain . algae builds up in drain and plugs it . mm
Dec 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Cant find the ice maker filter on my kenmore elite bottom-mount refigerator
It is on the back - behind a removeable panel. Top left side.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Adjusta cube ice maker spilling water
check at the back of refrigerator were water line comes in see if there have eany hole or check your freezer may be it (ajar)
Apr 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Funny fridge noise, kenmore elite trio
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Nov 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
134 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
