Question about Haier HP50B 50 in. Plasma Television
INPUT and MENU do not work
After turning on TV (1 year old Haier Plasma TV, Model: HP50B), NO SIGNAL icon shows up. Press INPUT or MENU buttons, get either SIGNAL icon or NOT AVAILABLE icon. Basically, TV does not work anymore. It happend when I hooked a newly purchased DVD and wrongly connected it to VIDEO 2 input. MY GODSON UN BEKNOWN TO ME PLUG IN HIS VIDEO GAME IN VIDEO 2 OF MY 50 PLASMA HAIRE HP50B AND NOW IT WILL NOT WORK HOW DO I FIX THIS PROBLEM
    Problem Solver:
  • 11 Answers
Your main pcb assy has shorted out. Replace it and it will fix your problem. part #tv-5210-173
Posted on Aug 18, 2010
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Sound is operating correctly ..However, there isn't any video , screen has an extremely faint picture
Sounds like a broken backlight. That's a write-off for an old set, or a factory warranty repair (90 days labor, 1 year parts). First make sure the TV is in TV mode (press mode on the set, or TV/AV on the remote).
Once in TV mode, press MENU and use the navigation buttons (arrows and ENTER) to choose the set to factory default mode.
Also make sure you have a working signal by trying another TV on the antenna or cable coaxial wire.
You can also try adjusting the brightness from the MENU.
If these steps do not work, call the Haier hotline listed in the manual: 1-877-337-3639
Oct 14, 2010 | Haier HLT71 7 in. Portable TV
Haier 50" blue screen
Replace your main pcb assy and it will fix your problem. I have had many come through our shop.
Mar 13, 2010 | Haier HP50B 50 in. Plasma Television
Haier 42 inch tv says no signal, not available
Your son, or daught hit some button, happend to me too. But i dont remember wat i did. Just try to unplug the tv and plug it bck in
Jul 21, 2009 | Haier HL19T 19 in. LCD TV
My 42 inch Haier Plasma has a no signal on screen it's only a year old can someone help I bought a new remote and that did not help ?
i had the same problem and i bought the new remote control and it did work at first i thought it was going to do the same thing but then i pushed the tv/use button and it worked perfectly.
Mar 13, 2009 | Haier HP42BB 42 in. Plasma TV
Haier plasma tv model 42EP24S 48"
Part number for Power supply of 42EP24S is TV-5210-36
HP50B is TV-5210-195
Good Luck
Dals123
Oct 07, 2008 | Haier HP50B 50 in. Plasma Television
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Haier HP50B 50 in. Plasma Television Logo
287 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
