Question about Kenmore Dryers
Won't start - 3 beeps when Start button pushed
This is a brand new dryer, it has not worked yet, and when I select a timed dry cycle and press the Start button, I hear 3 beeps. The door is closed, and I have even put some pressure on both top and bottom in order to ensure it is closed, but the same thing...beep beep beep.
  • 6,784 Answers
CHECK THE FOLLOWING--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
Posted on May 31, 2009
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Brand New Whirlpool Dishwasher won't start, can't change program eiether
Make sure the dishwasher door is firmly closed, press and hold the start pause button for about 5 seconds, this will clear the cycle, The try selecting a wash cycle and push start.
See if this helps.
Mar 04, 2012 | Whirlpool Dishwashers
The start button is flashing red and beeping and the drying cycle won't start. Help!
  • If the machine shakes or makes a lot of noise, make sure the dryer is level. Some shaking is normal, but it shouldn't bounce around like it's itching to go somewhere. Adjust the leveling legs. They just screw and unscrew. Check to make sure the load inside the dryer is properly distributed and is not all clumped together.
  • Match the control settings to the type of load, and make sure you're not overloading the dryer.
  • Check that the ducts aren't blocked if the clothes take too long to dry. Look for lint or missing socks. Check to make sure the ducting isn't kinked, and make sure the outside dryer vent flap moves freely and isn't blocked---by snow, for example.
  • Sort your clothes by weight if they aren't drying properly. Lightweight clothes should be dried separately from items like comforters.
  • Make sure the lint drawer is empty.
  • Press the "Stop" button or press the "Lock" button for three seconds if the controls don't work. Press the "Power" button to wake the dryer up if it won't start. Make sure the "Delay Start" button isn't flashing if the machine fails to start. Press "Start" again.
  • If you see only lights displayed on the screen and no numbers, it's normal. The dryer has detected a low level of moisture. Other normal behavior is when the time remaining jumps to a lower number---it's revising its estimated time remaining. When you can't make a selection and the dryer beeps twice, the dryness setting is incompatible with the chosen dry cycle hope this helps please tell me if it does
Dec 06, 2010 | Zanussi Dryers
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2010 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
I just installed a new Kenmore Elite HE5 Steam clothes dryer. Everything powers up. Cycles can be selected and adjusted. However when pressing the start button, the button beeps 3 times and the dryer...
remove front panel and look at tec sheet inside / it will tell you what is not working . make shure all the packing has been removed and power cord is proper .. 3 beep are a code . tec sheet will tell .. mm .
Nov 24, 2009 | Refrigerators
New HE5t steam dryer will not turn on
What was wrong with your dryer? I am having that same problem?
Dec 27, 2008 | Kenmore Dryers
GE DPGT750GC Gas Dryer Problem
Using the
Troubleshooter
To locate Troubleshooting Tips for common dryer
problems:
Press the HELP button.
2 On the Touch Screen, select TROUBLE
SHOOTER
3 On the Touch Screen, select the problem
description from the list. You can use the arrows
at the right of the screen to scroll up and down
through the list of additional problems.
4 On the Touch Screen, select a possible cause
for the problem and follow the on-screen
instructions to find a solution.
Pressing the HELP button then selecting HOME
SCREEN HELP
allows you to find additional
information on features found on the Home
Screen. Touch any pad on the Touch Screen for
an explanation of that feature. To exit the feature,
press the BACK button.
DID YOU ATTACH THE SERIAL CABLE?
Attach the serial cable for washer and dryer
connection to the serial port on the back of
the dryer.
Attach the other end of the cable to the
washer before pushing the washer into its
final position.
Problem Possible Cause What To Do
Dryer won’t operate Control panel is asleep • This is normal. Press POWER, the
touch screen or any button to activate
the control panel.
Dryer is unplugged • Make sure cord is plugged securely into
a working outlet.
Controls are not set properly • Make sure the cycle was set correctly,
close the lid and press START.
Fuse is blown/circuit breaker • Check house circuit breakers/fuses.
is tripped Replace fuses or reset breaker.
NOTE: Electric dryers use two fuses
or breakers.
Electronics need to be reset • Unplug dryer, wait 2 minutes, plug
back in and press POWER.
START was not pressed after • Press START.
a cycle was set
Door was opened during • Close the door and reset cycle, to the
the dry cycle beginning if necessary. Press START.
Dryer is too cold • If the dryer has been exposed to
temperatures below freezing for an
extended period of time, allow it to
warm up before pressing POWER.
Otherwise, the display will not come on.
Hope some of this helps. here is a link to the manual:
http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=DPGT750GCPL
Nov 29, 2007 | GE DPGT750GC Gas Dryer
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Oct 17, 2007 | Kenmore 62062 Electric Dryer
Dryers Logo
138 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
