Question about RIM BlackBerry Bold 9000 Smartphone
Soap covered cellphone
Yesterday my blackberry bold was covered in he laundry detergent. The keys stuck and the screen has soap under it. Is there a way to clean it?
    Scholar:
  • 71 Answers
I had the exact problem, but with sunscreen and water. Now...whatever anyone says about my post. I did this sucessfully and revived my Bold and it works as new (and saved me $500 from buying a new one)
1. If you have insurance, then you should go to the store and tell them you lost the phone. You warranty is now voided if you go the phone wet.
2. You will have to remove the battery as soon as possible.
3. You will have to completely take apart the phone. Its easy and only 6 screws. Look on YouTube for the video.
4. What I did, is I took all the pieces apart, including removing the lcd screen, trackball from the main board (and if you like the speaker for the earpiece, its magnetically connected). There are no moving parts on the phone so the reason it doesnt work is that the soap is creating a connetion to circuits that shouldnt be connected thus the phone doesnt work. ie: in layman terms, the metal parts of your phone are dirty.
5. I used a sonic jewelry cleaner that was large enough to just submerge the pieces.(I had bought one on Amazon a while ago, it was around $20) I used half rubbing alcohol and half DISTILLED water solution (distilled water has no particles in it). One piece at a time (not the lcd screen...more on that later), I ran the cleaner for 3 minute cycles about 5-8 times (replace the solution every 2-3 times). After this is done, the connectors will be sparkling clean again. Let the pieces dry for at least 24 hours. (some people put the parts individually in a bag of rice as it draws all the liquid away from the pieces)
6. The LCD screen should not be submerged in liquid. Use a QTip and rubbing alcohol to clean the connector and let dry. If the screen is still streaky when its repowered, it needs to be replaced. You can find them on Ebay or Amazon for about $40.
7. Its just that easy. Examine your clean parts. Depending on the amount of corosion or dirt on your parts, you may need to touch up connectors with a QTip and rubbing alcohol.
Some issues:
1. LCD screen (already discussed)
2. The battery short circuited the main board bc it wasnt removed quick enough. This mean that phone is shot and wouldnt even turn on.
3. Battery has been damaged and you need a replacement.
4. Cleaning as above may leave a spot on the camera lens (camera is sealed, so its really hard to get fluid behind the lens). Take a QTip, rubbing alcohol and clean the lens off.
5. A possible surge from a wet battery may have compromised the software within the unit. If so, simply reload the software through the desktop manager.
Id be happy to answer any questions.
Posted on Aug 04, 2009
    President:
  • RIM Master
  • 688 Answers
Your going to have to open the phone up and clean it out manually. remove the battery and don;t use it until this is accomplished. it could cause further damage.
here is an excellent video from you tube on how to take it apart.
http://www.youtube.com/watch?v=SGXToCiqqM0
Remember to work slow and don;t force the plastic it will break easy.
Posted on May 31, 2009
What type of laundry soap does it use and how much per load?
You did not post any info on the make and model. The front loading type of washing machines MUST use "HE" types of detergent. This is because a front loading machine causes suds and regular detergent is not made for reduced suds. The best laundry soap according to consumer reports is Persil. You don't need very much either. Most people use way too much detergent.
Jan 12, 2017 | Washing Machines
My GE Profile washing machine leaves soap suds in the bottom and on the clothes. I use Cheer liquid detergent. My husband says it is because of placing too heavy of items, such as towels, in the machine....
Use ONLY the recommended amount of detergent per the label on the detergent.
Pour detergent in the tub first then start the water,then add the laundry.
Do not overload the machine.
Use a bathroom scale to weigh 12-15 pounds of laundry and no more.
Big tubs invite more laundry.
Don't be fooled by a big tub.
Feb 20, 2011 | GE Washing Machines
Does the Neptune have to have HE laundry detergent?
Yes you need to use HE detergent is this machine.1st reason is regular soap will suds to much and make the unit go into suds lock. 2nd HE soap will not damage the bearings and seals like regular soap could. 3rd He will clean better and you will be using less product...
Sep 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
What detergent brand do you suggest with front loading washer?
We use 2x ultra ALL due to having allergies in our family. It is free of perfumes and clear of dyes. We only use 1/4 of the cup (or less) that is supplied with soap container and double rinse. That's the great thing about these washers, they use alot less water and don't need the extra soap as well. Even with the double rinse, at the end of the full cycle, we still see an occasional soap bubble near the door. Hope this helps!
Mar 25, 2010 | Frigidaire GLTF1670A Front Load Washer
I make homemade liquid laundry saop and when I use
you NEED to buy real washing soap from a store. I recommend Tide because you may be mixing wrong ingredients or not adding something. If buying new/real soap doesnt work i would go to a sears or email sears at their website and tell them.
Feb 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Laundry Detergent
this usually depends on the type and brand of detergent you use. for example if you use standard detergent and it takes 1 cup, then you use concentrated detergent and it takes 1/2 cup. you have to check the detergent container for proper amount to use. for most detergents it is around 3/4 to 1 cup of detergent.
Ps. dont forget to rate my answer please. Thanks.
Dec 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Ryobi 3000 psi pressure washer detergent injector
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
Oct 13, 2008 | RTO 1800 PSI Pressure Washer
LAUNDRY SOAP
Yes you can but remember to only use 2 tablespoons of detergent.  It may not say it in the owner's manual but it is what the factory is telling us to relay to the customers.
May 24, 2008 | LG WM-2277HW Front Load Washer
Moldy Smell
try running about 3 cups of vinegar in your washer and always leave the door open when you are done doing laundry
Dec 10, 2007 | Kenmore Elite 45986 Front Load Washer
RIM BlackBerry Bold 9000 Smartphone Logo
187 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
