Question about Uniden Cordless Phone
Unable to register the handsets to my Corded/Cordless combo phone
I tried to program the handsets from the base unit to no avail. I HAVE TRIED TO REGISTER MY PHONES, BUT NOTHING WORKS.WHAT CAN I DO?
  • 4 Answers
I would need to know the make and model of your phone and how old it is. If it is a recent purchase, the vendor company can offer technical assistance. If it is an old phone, contact the manufacturer. There is no blanket solution because each phone has individual characteristics. If you still have the manual, it can offer solutions. I love cordless phones, but no matter what I do, I find a cell phone is the only real way to be mobile and talk on the phone. But I refuse to pay the high cost of cellular. Then I found this: (http://www.3centcell.ca/admin/affiliate.aspx?314 )
Posted on May 31, 2009
Unable to change handset registrations from old base to new.
Hello Linda,
See if my FixYa Answer from this previous post helps to Deregister and Register your old handsets to your new base.:
My phone says no link to base but am right beside it
Regards,
-Ellsworth
Mar 25, 2017 | Panasonic KX TG4031 Cordless Phone
Can I connect a CL82409 handset to a CL82409 base system
Yes, and no.
When you buy the new corded base station (CL84109) with 1 handset, that base unit by default is "paired" with only the 1 cordless handset that came with it.
While you can plug both base stations into the landline wall plugs (RJ-11), and when the line rings, both base unit phones will ring and will each operate as independent corded phones would.
But, in this scenario, the cordless phones communicate only through the base unit they are Paired with. The cordless phone paired with the CL84109 corded base unit will not be able to transfer or Intercom between the cordless phones paired with the CL82409 base unit.
However, if you want to transfer the cordless phones that originally came with the CL82409 base unit to work directly with the CL84109 corded base unit, you can likely "Pair" them to work directly with the CL84109 corded base unit for a total of 5 cordless phones to be paired to the CL84109 base unit.
Consult the User Guide that came with the CL84109 base unit for instructions on how to Pair additional cordless phoned to this base unit.
The CL84109 can be expanded and paired with up to 12 cordless phones. So, this should be do-able.
Keeping in mind that the CL82409 will no longer have any phones paired to it and will thus be useless from that point on. (unless you pair more expansion cordless phones to it again)
Mar 13, 2011 | AT&T CL82409 Cordless Phone
You must charge each phone individually on the main base unit for at least 20seconds before use. Do this with each phone-again on the main base unit, then you should be able to register and return other phones to separate cradle. I hope this works for you
May 26, 2009 | Uniden Cordless Phone
I have a GE cordless handset Model 27911 that I cannot get to register to the main base unit which is a GE Model 27909. I have tried followed the instructions and still the handsets says "Not register."...
trun off phone and remove battery
remove power from the base unit
and leave them unpluged for 5 mins or more
then turn both units on
and replce onto base unit . Good luck
May 04, 2009 | Uniden Cordless Phone
Base Unit unable to use
Your base has taken a strike to the processor and it is stuck trying to boot up. If you have cycled the power already and it stays stuck, it is not going to boot. Buying a replacement base (you can get just the base a little cheaper than the base/handset combo) and recycling your old one properly is the way to go if you want to get your base up anytime soon. Once you get a base, you will register your handsets to it, and reset your answering machine greetings, etc. If you have stored settings in your handsets such as the dialing directory, those will still be there. Just google "cordless telephone repair" and the first couple non sponsored links carry the base only. Good Luck
Jan 09, 2008 | Panasonic KX-TG2740 Cordless Phone
Can not get the second handset to register to the base
This is the registration procedure
Step 1: press MENU-6 and select 3 “SET BASE”
Step 2: press the REG key on the master base
Step3: press register to finish the registration procedure.
• After the registration complete, handset 11 and handset 21 can
2-WAY intercom with each other
If issue persists reset the unit start registration by using 2nd unit that currently unable to register. if issue continues please inform for further troubleshooting
Good Luck
Jan 01, 2008 | EnGenius SN 920 Ultra Cordless Phone
Microphone does not work
I had a similar problem. I noticed that if I put the call on hold when I took them off hold, the mic would work for approximately 5 seconds, so I figured it must be a "software" problem.
On the base unit, I used Setup Base > Deregister All and then re-registered by handset. The mic is working again (for now).
Dec 04, 2007 | AT&T E252 Cordless Expansion Handset...
PROBLEMS with phone
Had the same issue. I have two units each with a handset, and one handset went to "out of range" status and stayed that way even after recharging. I tried to register it with that base and no luck. I then tried to register it with the other base and it worked. Then I tried to "swap" the handsets and no luck - it seems that the registration process on the one unit is toast so now I can only use the handsets with one of my two base units.
Oct 22, 2007 | Motorola Mobility MD7091 Cordless Phone
UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Oct 17, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
TWX977 submersible unable to base register
push menu on base station - select register phone
push # sign on twx977 phone at the same time
phone will register on 9485 base station and unit
Sep 09, 2007 | Uniden TRU9485 Cordless Phone
Uniden Cordless Phone Logo
141 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
