Question about Biostar P4VMA-M Motherboard
How connect some cables
I was disconect because I was clean, now I don`t know how to connect the light of the HDU, an other similar
    Novelist:
    Champion:
  • 256 Answers
Dear Sir; without an instruction manual of your motherboard, I don't suggest that you, ever connect the wires, or attempt to turn it on, ON GUESS ONLY. From what I see you have all the info you need. Go to Biostar and buy a manual. They only cost about US$ 10.00 and then follow instructions to an iota. You are playing with fire...
My name is Constantin (arzconst)
Posted on May 31, 2009
No high beams, even to flash.
You can try this, it worked on a friend of mines ES 300 with the similar problem, Disconnect the wires from the battery clean the terminals on the battery, Now instead of connecting the cables back to the battery connect the cables to each other- While the cables are connected this way make sure that they DO NOT come in contact with ANYTHING metallic on the car. Leave the cables connected this way for at least 20 minutes, then reconnect the cables back to the battery, make sure you have your radio code before you disconnect the battery,
Dec 05, 2014 | 2001 Lexus ES 300
Turn on ignition hit the start button and all indicator lights go out,and does not start
First check to be certain that the battery is fully charged
Next, be certain the battery terminals are clean and tight. Don't just look at them, disconnect the cable from the battery and clean the contact surfaces with a wire brush. They should be tight enough so that you cannot easily twist them by hand.
If you still have a problem, locate where the ground wire coming from the battery is connected. to the engine or frame Disconnect it and clean the contact surfaces, then replace it and tighten the connection.
The type of problem you describe is usually caused by poor ground, however if you still have a problem (after disconnecting the ground cable from the battery) trace the positive wire from the battery to its connection and be certain it is clean and tight.
Let us know that solve your problem
Nov 14, 2011 | Motorcycles
Aeg competence e-4100-m, pnc940316609, s-n 31280933 Problem: I have just succesfully changed torpedo shaped component cable tied in to the wiring loom. It had 2 white and 2 blue wires coming. BUT... I...
If there are no other connection ports, and you only disconnected the three, it is possible that (if this is an aftermarket wiring harness) the third was put in for similar units with an additional option of some sort, and is not needed for your model. However, I highly suggest referring back to the place of purchase, as well as the manufacturer to find out for sure before plugging the unit in and using it.
Please let me know if you need further assistance,
carsandcomps,
Guru, Premium Expert, Phone Support (Chat) @ Fixya.com
Jun 19, 2011 | AEG B2100-4 Electric Single Oven
Where do i connect wires on new Intek briggs & stratton motor going into cox compact tractor Model09M7. Red, white, grey & black wires from motor.
i have similar problem robjanottle. the red connects to the power cable in the equipment harness and the white connects to the light switch.this is from B & S website where u can get wiring diagram for dual circuit alternator. ******** if i know where the grey and black wires go. the grey is attached to underside of fuel bowl but don't know where it ends up and maybe black is earth? i am going to local mower dealers to have a pretend look to buy mower but will only be interested to find where this friggin' grey wire goes to. good luck mate
Apr 24, 2011 | GPS
Installed new battery on LT1045 CUB CADET----- Now have no panel lights or instruments and starter only clicks
Make sure the fuse link found in back of instruments did not blow, if so replace and solve problem . But because you also have a starter that clicks I advise you to disconect the negative cable from battery and clean copper with wirebrush, then remove other end and do the same. secondly repeat that with posotive side too. lastly disconect the key switch from its cables, if possible clean contacts and if not just plug them right in again and you should solve the problem.
Mar 11, 2011 | Garden
Cable light blincs for a while then stops blinking and goes solid
This could be a problem with your ISP or the modem itself. Try calling your ISP and explain to them what is happening. They can test your connection.
Hank
Aug 18, 2009 | Toshiba PCX2600 (c40054) Modem
Diconneted battery to clean cables now abs and brake light is on
disconect positive cable on battery weit one min and conected back on will reset ewrting make shore ignation kay off position wen yu disconect batt
Mar 11, 2009 | 1999 Jeep Grand Cherokee
Wireless network disconects when connecting xbox 360
Are you connected to the router wired, or wireless?
Have you set your laptop to a static IP on you network, and your X-box is set to the same?
Jan 29, 2009 | Linksys Wireless-G WRT54G Router
Biostar P4VMA-M Motherboard Logo
59 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
