Sound problems I moved my computer recently and when I plugged it all back in the sound wont work. I've gone to device manager and its says everything is ok. I can hear sound if I put headphones in so I dont think it is the speakers. Dont know what else to do
  • cathfuidge May 31, 2009
    Thanks all problem now solved
  • meteshadow May 11, 2010
    if you did what you told. there is a problem with the speaker. have the speaker power conncet or sometihng else expect plug to computer?
    President:
  • 688 Answers
Your speaker connections are plugged in incorrectly or the speakers are not plugged in and powered on.
check the back of the computer where your speakers are plugged in and make sure you speakers are plugged into the right colors
Posted on May 31, 2009
  • 40 Answers
Do the speakers need to be plugged into a wall outlet for power? Are you sure you have it plugged into the spaker jack? (It will be the green one) Thats about all I can think to do first.
How do I diagnose and fix my laptop's sound problem? Should I just throw it out the window?
which operating system
You receive an error that states: There might be a problem with your audio device
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 26, 2012 | Fujitsu Siemens Amilo Pi2515 Laptop...
My speakers are not working. I'm on an HP and have Philips speakers. They have worked fine before, but we recently moved and since the move they have not worked. Help?
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 23, 2011 | HP Audio Players & Recorders
I have an HP Pavilion 6000dv...specifically, it's a 6119us. I have no sound at all. I've checked the device manager, nothing is muted, I've gone through the troubleshooting program...still...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 28, 2011 | Computers & Internet
Hi, my laptop sound has gone dead in a sudden. When I open the volume mixer, I can still see the green bars jumping up and down on digital output device (SPDIF) but nothing at all for windows media player...
Hello patrick886,
If your volume mixer is still showing the noise bars moving, that's great. It means the computer knows sound is coming from somewhere, the fact that you can't hear it, indicates there's a problem with where to send that sound (aka your speakers). Now with the no sound coming out, I'm guessing you are talking about the internal speakers and not external ones.
Have you recently installed any kind of music editing software? Mp3 player such as Winamp, iTunes or other music related programs? I'd start by checking the device manager to see if the speakers are at least being detected.
I've put together a nice little picture for you. Hope it helps!!
My sound wont work on my emachine
There are a few simple things to check first:
  • Make sure your computer has a sound card.
    You must be logged on as an administrator to perform these steps.
    1. Open Device Manager by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. Expand the Sound, video and game controllers category. If a sound card is listed, you have one installed. If no sound card is listed, You will need to install one. See Install or remove a sound card.
      gl_ico.png Note
      If you think you have a sound card installed but you don't see it under the Sound, video and game controllers category, expand the Other devices category and check any devices listed there.
    3. If there is a yellow question mark next to the name of the sound card, there might be a problem. Right-click the name of the sound card, and then click Properties.
    4. Click the General tab, and then look in the Device status box to identify problems with the sound card.
  • Make sure your speakers are plugged into a working power source and turned on.
  • Make sure your speakers are correctly connected to the computer.
    On your speakers, find the cable that plugs into your computer. Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer. For example, if the cable is a 1/8 inch cable, there should be a round jack for it on the back of the computer. If it is a universal serial bus (USB) cable, it will plug into any USB port on your computer.
  • Make sure that the speaker volume is not muted or turned down too low.
    1. Open Volume Control by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then, under Audio Devices and Sound, clicking Adjust system volume.
    2. Under Main Volume, move the slider up or down to raise or lower the volume.
    gl_ico.png Note
    Some mobile PCs have an external volume control on the outside of the case. If you're using a mobile PC, check the external volume control.
  • Make sure your headphones are not plugged into the line out (headphone) jack of your sound card or computer (unless you want to be listening with headphones rather than speakers). When you plug in headphones, most computers automatically cut the sound to the speakers.
  • If you need more help post back!
    Thumbs and testimonial are welcome!
Mar 14, 2011 | eMachines Desktop / AMD Athlon Processor /...
My speakers wont work, everything is plugged in, and nothing will still not work.
I know this was old query, but i recently had a problem with sound cutting out. Discovered if I jammed a spoon between the two cables input to the sub box, I could get sound back. Today finally got around to opening it up and discovered the soldering on both sides of the 8 pin anchor leads were broken. The pressure of the spoon jam allowed the connection to "seat" temporarily. Fixed with 25w iron and 60/40rosin core 0.032" solder. Wicked the old broken mess off and applied dab of new shiny complete solder. Good Luck all.
Sep 11, 2010 | Altec Lansing Audio Players & Recorders
Hiya i have recently moved my computer from the front room to a bedroom and plug everything in, i thought everything was fine until i tried to play some music so i checked all the connections/leads and...
Hi try looking over it again with the help of this https://www.download.p4c.philips.com/files/s/spa7300_79/spa7300_79_dfu_eng.pdf just make sure all connections are pushed in properly as those plugs have a tendency to not plug in all the way
May 04, 2017 | Philips SPA7300 2 Speakers
Sound card problem
go on the net and download the drivers for that make of sound card
Apr 07, 2017 | Apevia Keyboard for Acer Aspire 5520,...
No Sound
Please try to check the sound device status if its working properly thru right click My Computer icon > Properties > Hardware tab > Device Manager > (double click) Sound, Video & Game Controller OR System Device > System Speaker. also, take note of the Troubleshoot tab. If still it doesn't work, I think you have to reinstall the sound driver (from its motherboard software CD if it's built-in type). best regards
May 12, 2009 | HP Computers & Internet
Durabrand uc-280 don't work!
go to device manager locate the speakers, right click and update drivers, if that fails search google for that sound card driver.
Nov 12, 2007 | Audio Players & Recorders
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
