Question about Motorola Mobility RAZR V3
Motorola razr display
Hey this is my thrid razr I returned one for a software malfunction and my second was washed in washing maching, now this one has some display problem i went to check my phone and the external and main screens look like the brightness was turned down so much i can't see almost anything at all i know its on because i can still speed dial and at the right angle see the screen. I already reset the phone and that didn't work. Please help?
    Sergeant:
  • 452 Answers
I can understand this trouble, So You pliz visit service centre of motorola, ur handset is in warranty period, they will repaire it for u.
Posted on Oct 23, 2007
I found a small part (looks like the top part of a pen) in my washer, now when i turn on the washer the goes in but does not stop, does not start the wash cycle. Also door keeps locking and unlocking.
How to run a diagnostic test:
  1. Unplug power cord, then wait 30 seconds.
  2. After plugging in, follow these instructions...
To Enter SERVICE MODE: Press Signal-Delay-5ignal-Delay (within 30 seconds of plugging in washer).
To Exit SERVICE MODE: Repeat Signal-Delay-Signal-Delay.
Here are the possible tests to run (TEST LIST). The error codes from t02 will probably be the best indicator of your problem. (scroll down to bottom to see what each command button does once you are in test mode)
  • "t01"
    Model ID
    Verifies (or sets on new board) the proper Model id
  • "t02"
    Error Codes
    Lists up to 10 control-detected problems
  • "t03"
    Software ID
    Verifies using latest Control-eePROM-lnverter software
  • "t04"
    Exercise lCD/lEDs
    Verifies that all the displays and buttons work
  • "tOS"
    Pump Test
    Tests drain-out pump
  • "t06"
    Pressure Switch Test
    Fills to all 3 levels, then pumps out water
  • "tOT'
    ThermistorlHeater Test
    Verifies that both the Thermistor and Heater work
  • "t10"
    Tumble Test
    Verifies Washer Tumbles (I.e. Wash cycle)
  • "t11"
    Spin Test
    Verifies Washer spins
  • "t12"
    Dispenser Test
    Verifies Dispenser fill works-for all four fill modes
  • "t13"
    EOl Test
    Performs End-of-Line test sequence
Button Commands (based upon test mode)
t01 prerequisites: none
Start Displays defined Model id (01-04); displays "---" if new board (to set Model id, rotate knob unlil desired id [01-04] displayed, press and hold "START' key to program desired model)
Power Returns to "t01"
t02 prerequisites: none
Start Displays most recent error code (EOO=none)
Start Displays previous error code (up to previous 10)
Hold start Clear all error codes (and then displays EOO)
Power Returns to "102"
t03 prerequisites: none
Start Alternate "cod" and Control Software version
Start Alternate "EE" and eePROM version
Start Alternale "Inv" and Inverter Software version
Power Returns to "103"
t04 prerequisites: none
Start loops on lighting lED's, LCD and cycle ids
Any button Beeps when depressed
Power Returns to "t04"
tOS prerequisites: none
Start Displays "P" and pump for 60 seconds
Power Returns to "t05"
t06 prerequisites: none
Start Displays "E" (for Empty) and starts filling when reaches Foam level-displays "F"
Start Fill, when reaches Main level-displays "nl"
Start Fill, when reaches overflow leve~ displays "OF," pumps out, displays "E" when tub empty
Power Returns to "t06"
t07 prerequisites: Main level pressure switch must work
Start Displays temperature in OF, fills to main level, turns on heater up to 5 minutes, displaying rising temperature
Power Pumps out water and returns to ''t07''
t10 prerequisites: none
Start Displays "It" and tumbles tub alternating the direction every 5 seconds
Power Stops tumbling and returns to "t10"
t11 prerequisites: none
Start Spins to 400 RPM displaying increasing RPM
Start Spins to 1100 RPM [Greater than or equal to 1000, displays "Axx"; Greater than or equal to 1100, displays "bxx" (xx, 0 to 99)] [currently error-automatically goes to 0 RPM]
Power Stops spinning and returns to "t11" when stops
t12 prerequisites: none
Start Displays "pdt" and fills via pre-wash chamber
Start Displays "ddt" and fills via main wash chamber
Start Displays "bdl" and fills via bleach chamber
Start Displays "Fdt" and fills via fabric softener chamber (stops if reaches Main level during any fill)
Power Pumps out water and returns to "t12"
t13 prerequisites: none
Start Starts EOl test sequence (NOT used in Repair)
Power Returns to ''t13''
Once you have the diagnostic codes, check this post for the meaning of the codes:
http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
Jun 25, 2011 | General Electric WCVH6800J Front Load...
Washing maching error code IE
WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Dec 19, 2010 | Samsung Washing Machines
Wife washed RAZR. appears to work but screen is blank (dark) Any easy solutions?
your display is damaged please give it to a authorised motorola service centre
Oct 07, 2009 | Motorola Mobility RAZR V3
Motorola razr v3 display has stopped working. i
Hey just go to motorola or any mobile shop they will replace its display internal wire...
Jun 26, 2009 | Motorola Mobility RAZR V3
I need the PUK code (because I entered the wrong access code too many times). Its an AT&T motorola phone, model bt60
Dears,
my previous pin code was 4351. After several attempt on display says pin blocked.enter puk code.
please advise me by return to solve the problem
nokia 6555
regards,
Moe
Aug 02, 2008 | Motorola Mobility RAZR V3
Motorola razar v3
you need to download the usb driver from www.motodev.com
May 17, 2008 | Motorola Mobility RAZR V3
Motorola RAZR V3i Camera Problem.
Hey cmxa,
It is possible that the flex connection in the phone has become loose. (seems to be a common problem with the v3's) Or worse, your camera module has gone bad. Is the unit still under warranty? Send the unit in for repair, and they should be able to resolve it quite quickly.
Hope this helps,
cHiPz.
Mar 29, 2008 | Motorola Mobility RAZR V3i Cellular Phone
How to install theme in motorola RAZR V3i
hey!!!!! istead of installin themes its a better option to install skins!!!! you can find skins for the v3i in most of the websites!!! To install these skins you need a software called skiman which can be downloaded from motomodders .net.... also remember to download the p2k drivers b4 installin them!!!!
Feb 20, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola v3c got washed
you have to buy a special tool from home depot hex drivers should costabout 7 dollars
Nov 07, 2007 | Motorola Mobility RAZR V3
Motorola V3 RAZR
since it is new you can return it to the store you purchased it. it is covered by warranty. or maybe your batt is not yet charged...
if everything is fine, then have your phone repaired to a trusted service center coz usually the phone software is corrupted. have your phone reprogrammed...
Oct 19, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
97 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
