HP W2338 MONITOR GATEWAY 6800 MONITOR CABLE DOES NOT HAVE CORRECT CONNECTOR TO COMPUTER MONITER CABLE HAS MALE CONNECTORS AT BOTH ENDS. NEED ADAPTER WITH MALE CONNECTOR TO MONITOR AND FEMALE CONNECTOR TO COMPUTER
    President:
  • 688 Answers
You should be able to either get the right cable or get an adapter at a computer store.
Posted on May 31, 2009
Screen has a yellow tint that I have not been able to get rid of.
Try this instead
change out the connector in the back of the computer, or the monitor cable (Replacement cable *see below) While the connector/ cable is going out it can give a solid hue across the entire screen.
You can also try updating the video drive through device manager to see if an updated is need.
Hope that helps.
Fullink Premium Blue Connectors HD15 Male to Male SVGA VGA Long Video...
Sep 27, 2015 | HP 2009M Monitor
Model 2200W Proview LCD Monitor - How do I connect it to HP Laptop?
Since you don't provide the laptop model, I assume your PC has at least a 15 Pin VGA connector. You will need a 15 pin male VGA to 15 pin male VGA cable, just plug it at the laptop and the monitor, that should do. If your laptop has also an HDMI or DVI or Display Port, you will need a proper cable or adapter.
Jul 30, 2014 | Proview Computers & Internet
Can i get an adapter for my emachine monitor to go into a dell desktop ...my lead i have now doesnt fit as unable to screw it in
YES.
I believe it is time now for the guessing game............
1) Is the monitor about so high, and so wide?
2) Does the monitor look like a small TV, or is it flat in appearance?
3) What does the monitor cable look like?
4) Is your hair Brown, and do you smoke cigarettes?
NO.............just wanted to see if you were following along! Geez!
An Analog monitor, such as a CRT type of monitor, uses a VGA cable,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for a VGA Cable example.
Flat LCD screen monitors are Digital.
Some may have a VGA Cable attached, but the best cable option is a DVI cable,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
(Click on any photo on those two Wikipedia pages, to enlarge)
Using these two examples, does one apply to the eMachines, and one apply to the monitor?
Let us say the monitor has a DVI cable.
The eMachines Desktop PC has a VGA port. (Connector)
For this you would simply use a DVI to VGA adapter,
http://www.directron.com/dviadapter.html
Now notice...........this is a VGA MALE to DVI FEMALE.
The DVI cable on the flat LCD screen monitor, has a male connector.
The contact pins of it go into socket holes, in the DVI end, of the DVI to VGA adapter.
The VGA port on the eMachines, has socket holes.
The male VGA connector end on the DVI to VGA adapter, has contact pins.
Point?
Make sure you get the correct DVI to VGA adapter.
There is a male DVI to female VGA adapter, also.
This is just one example.
For instance I'm using an HP 2009M 20-inch widescreen monitor, AND an RCA 26-inch HDTV, as dual monitors.
Presently using the HP 2009M with a DVI cable, and the RCA L26HD31 HDTV with a VGA cable.
(I'm also using an ATI Radeon HD5450 graphics card. Pretty 'pud', but it does OK for what I want)
Primer;
A computer sends out a digital signal. To get the best graphics quality, you ideally use a monitor with a digital cable. (DVI, etc)
When you use an Analog monitor on a computer, the computer has to change the digital signal down to an Analog one.
Therefore the graphics quality is not as great.
Digital cable technology now, is DVI, HDMI, Display Port, and Mini-Display Port. And some others I'm sure I've forgotten.
http://www.hardwaresecrets.com/article/Video-Connectors-Tutorial/157
For additional questions please post in a Comment.
Also post what the monitor manufacturer name, and model number is. (Look on the back)
Are you using the VGA connector on the motherboard, (Back of computer), or do you have a graphics card installed?
If you have a graphics card installed, what is the manufacturer name, and model number?
Regards,
joecoolvette
Mar 06, 2013 | Dell Dimension 4300 PC Desktop
Connect wii to vga moniter Hp s2031
Hi Dear Friend,
You have a monitor with in-built VGA Port and you have laptop in-built VGA Port then why you are not using simple VGA cable to both port, Please don't use any other type to Adapter.
Thanks to Visit on Fixya
Sep 13, 2012 | HP S2031 20-inch Diagonal Lcd Monitor -...
Missing adapter or plug in connection to 15 balance mointor model 2015
The Balance CM2015 monitor uses a VGA connector,
http://www.ebay.com/ctg/Balance-CM2015-15-LCD-Monitor-Black-/52125929
(The above is for reference only. Not advertising)
A VGA connector is also referred to as a 15-pin D-Sub connector,
http://en.wikipedia.org/wiki/VGA_connector
This is information on a DVI cable, and DVI connector,
If this is the monitor cable you have, you need this type of adapter,
Now LOOK closely.
This adapter has male pins that stick out, and go into a female VGA connector on the monitor. The DVI side of this adapter has socket holes, for a male DVI cable.
IF, your monitor has a male VGA connector on it, and the DVI cable you have has socket holes, you need this adapter,
http://www.directron.com/dvitovga.html
If your monitor cable is not a DVI cable, post back with the style it is.
If nothing else post how many pins are in the connector on the cable, and how they are arranged.
Regards,
joecoolvette
May 27, 2012 | Computers & Internet
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
http://sewelldirect.com/dviaftovgam.asp
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
More information on the DVI connector styles, and the Digital Visual Interface technology,
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Regards,
joecoolvette
Jul 16, 2011 | Computers & Internet
Changing cable port
The monitor is a Fujitsu VL-15DX5G. 15 inch LCD.
The monitor cable uses a female DFP20 connector.
(Display Port 20-pin)
http://auction.thumbnail.image.rakuten.co.jp/@0_auc/image50/cb/4a/00010523850/a1/85/img00149858603.jpg
So you need a male DFP20 to male DVI-D adapter, or adapter cable.
DFP20 Male to plug into the monitor cable, and Male DVI-D (Dual) to plug into the graphics card's, female DVI-D connection.
So far, all I have found from a quick search is a Male DFP20 to Female DVI-D adapter, such as this example,
http://www.worldofcables.com/store/viewitem.asp?idproduct=768
Of course this won't do.
IF, this is all that's available for DFP20 adapters, you'll need an adapter of Male DVI-D to Male DVI-D, also. (Yes, I am aware of how crazy that sounds)
(It would appear, adapters are sold to connect a normal DVI-D monitor cable, {Male}, to a computer with a female DFP20 connector)
Should your searching only find DVI-D female to DFP20 male adapters, or adapter cables, then here is an example of a DVI-D male to DVI-D male adapter,
http://www.kvconnection.com/product-p/m-sgc-dvid-mm.htm
(DVI-D male to DVI-D male cable would probably be better as there would be less strain on the graphics card's DVI-D connection)
May 14, 2010 | Computers & Internet
Vga cable and power cord for monitor
The vga cable is a DB15, 3 ranks with male connector at each end,
(you can use a vga extention and add a little male to male adaptor at the female end to get finaly 2 males connectors)
And, the power cord is in fact an ac/dc adaptor, the replacement part is: 12b27-0428 (12v 5A 60w 4 pins) ...
just type de number 12b27-0428 on internet and you're on ...
Mar 12, 2009 | ViewSonic VG900b 19" LCD Monitor
BenQ FP91G+ Moniter
I am assuming you are using a VGA connector at the back.
There may be an issue with the physical connectors - make sure they are secure & screwed in ( The blue conne connector) has two screws on either side. Sometimes when the monitor is not connected properly to this cable it can cause problems. Also male sure this is the case at the graphics card end...
let me know
Also run Dxdiag.exe from the run command - This will let you know if there are any issues with the GPU.
Let me know
Mar 31, 2008 | Computers & Internet
Male moniter plug on both moniters(every one in the world) and motherboard
That Male connector is a serial port not video, you need to get a video card and plug the monitor to this card.
thanks for rating
Jan 10, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
