Question about Bose Lifestyle 35 Series II System
Error code 10 during sound calibration
Adapt IQ for Bose 35, speakers were in reverse position so I paused DVD sound calibration. Then message appeared on display error code 10 contact Bose. Please help
    Scholar:
  • 74 Answers
Please ensure that you have turned on the Accoustimass module, this can cause communication errors when calibrating. Also check that all connections are correctly plugged in as if one is not quite sat right this may give the error, just try unplugging them and plug them back in.
Posted on Dec 09, 2009
I lost my remote. i want to program my remote for my visio smart tv to control it. I cannot turn the bose on. need a code. etc
Bose® Solo TV sound system - Bose Product Support
worldwide.bose.com/.../solo_tv_sound_system/page.ht...
Bose CorporationDiscover product support for your Bose® Solo TV sound system. ... Learn about using existing universal remote controls with your Bose system. more » ...
[PDF]TV Sound System - Bose
worldwide.bose.com/.../assets/.../solo/.../owg_en_solo.p...
Bose CorporationSolo. TV Sound System. Owner's Guide ' Brugervejledning ' Bedienungsanleitung ' ...10. Step 5: Plug the other end of the audio cable into your TV ......................
Best Buy Bose - Solo TV Sound System : Questions ..
Dec 26, 2015 | Bose Solo 10 TV Sound System
Went to shut off my bose system and got a message adaptiq A/B off. how do I get rid of the message
  1. Have you got the original Adapitq DVD disk? Try running the sound calibration routine again.
Apr 24, 2014 | Bose Lifestyle 48 System
How adapt audio from 43 inch hd tv with no headphone jack to vivanco fms 2000 speakers
follow the chart troubleshooting and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Oct 14, 2013 | Televison & Video
I tried installing a set of Def Tech Pro Cinema 600 speakers to my Yamaha RXV667. They recommend two methods. One is to connect the subwoofer through a cable using the LFE port on the receiver. I've done...
I'd go with the second method of connection for this receiver if you want to use automated calibration that requires discrete control of each speaker. I'd expect calibration errors with Method One as you're not just monitoring the sub when you test it; and the L and R fronts would have sub chiming in during the test, too. That would surely confuse the automation.
You (or the receiver) wouldn't be able to adjust the sub independently of the fronts that way.
http://www.retrevo.com/support/Definitive-Technology-ProCinema-600-Home-Theater-Systems-manual/id/15013ci257/t/2/
I'd also be a bit leary of their claim you can set your speakers to Large. With only 3-1/4" drivers I wouldn't expect much in the way of realistic bass-handling or power dissipation.
From the manual...
"We encourage you to experiment with the various settings on your subwoofer, settings on your decoder, and hook-up options as described until you find the best combination for you."
Jan 24, 2011 | Yamaha RXV667 Receiver
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
Sound comes only fron one rear speaker
Did you try switching Speakers A and Speakers B button on the AV receiver?
Jan 10, 2009 | Bose Acoustimass 10 III System
Bose audio system error codes 31,33,30?
The trunk mounted 12 disc magazine changer with the Bose audio system is made by Pioneer. Mine is a bit flaky too so I try to avoid unnecessarily swapping out the CD's. Those error codes can mean anything from a defective/wrong disc type (it does not support MP3 discs), a disc being upside down, or forgetting to close the magazine loading door. It can also indicate condensation on the laser lens or a system malfunction. There may be a list of error codes in the owner's manual if you have one, I currently don't.
Assuming you have checked all of the possible human errors above, there are aftermarket sellers that claim you can adapt an aftermarket changer to the Bose system albeit with with inferior sound quality to the original system. Bose is typically well-known for it's audio quality. That being said, the other option would be to seek a repair facility that can repair these changers. There are some places on-line that repair car audio that also might be able to help.
A cheaper workaround might be to hook up a portable CD/MP3 player using a cassette adapter. Assuming the cassette player, amp and speakers are good, you would possibly still get fairly high quality sound from the Bose system.
Best of Luck!
SC442299
1996 Oldsmobile Aurora
4.0L DOHC 32V V8
Bose Audio w/ 12 Disc Changer
Autobahn Option
Jun 23, 2008 | 1996 Oldsmobile Aurora
Need Universal Remote Code for Panasonic DVD Home Theater Sound System
Need a remote for a Bose CINEMATE Digital Home Theater Speaker System. Where can I find one?
Dec 26, 2007 | Bose Cinemate Digital Home Theater System...
Bose Lifestyle  35 Series II System Logo
1,143 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
