Question about Philips GoGear HDD6330 MP3 Player
I ned to know how to open the unit to chaneg the battery
  • larryfink1 May 31, 2009
    i need to know how to open my hdd6330 gogear to change the battery. info from the last person was all wrong
  • larryfink1 Jun 01, 2009
    thanks, you got me headed in the right direction at least.
  • Philips Master
  • 19,396 Answers
At the bottom of the device where the charger connects, there are 2 tiny little screws, take them out, use a small knife or anything and push up into the front cover of the unit both sides, this with pop the cover off and you now have access to the hard drive and battery.
Posted on May 31, 2009
  • 3,230 Answers
There is 8 screw on the backside of that player,
and also may be some plastic locks on the top of it.
thanks
What is the size of my a/c Rheem 90-22383-10 from 1987
Is this the number on the iddor unit or the ourdoor unit?
Sep 18, 2014 | Heating & Cooling
Hi i m using canon lbp3300 printer, but when i m print the paper, paper jam in roller, pls help me.
If you find the problem often , chanege the tefflon sheet , otherwise change the fixing unit. It will solve the problem.
Dec 10, 2010 | Canon LASER SHOT LBP 3300 Printer
I have a motorcycle YAMAHA- XJR400 & one off the the cylinders is not working. i have had htat problem before, but chaneging a sparkplug fixed it. this time i have chaneged the spark plug but it did...
2 solutions bad coil for that cyl or bad spark plug . remove that
plug and put it in the plug wire and rest it up against the cyl wall
try to start bike and see if you are getting steady fire. or hit and miss.
if there is no fire, try your plug in the other cyl . if plug fires in that
coil you now know about where your troubles are.
Oct 21, 2010 | Yamaha XJR 400 Motorcycles
Unable to switch on. Have checked safety switch and fuse on home circuit board - OK Power on outside unit on and OK Remote control has new batteries and display OK Cleaned remote sensor panels on both...
as per the problem which you mentioned it clearly indicates that problem is with the switch in the wall unit.but you mentioned that you checked the switch and it is OK.
this means that the problem is with the main circuit control board of the wall unit.on that board the component is got blow-ned out or any of the component is got loose.you will have to check out with meter .if it looks looks then component needs re soldering but if its faulty or blow-ned out then that component needs replacement.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 31, 2009 | Heating & Cooling
I ned code for panasonic cq-vx100u the mecanic desconect the bate
bought car yesterday they changed the battery and now there is a code display that has the unit locked up
Jun 05, 2009 | Panasonic CQ-VX100U Car DVD Player
Wont start
Main fuse on the battery +ve terminal has blown (350amp) The engine is probably solid had the same problem when the aircon seized on my 15 dci
Apr 28, 2009 | 2003 Renault 181
Starting code
I had the same problem if you look in your owners manuel your code to your car is there if not vin # and the dealer should help.
Dec 20, 2008 | 2006 BMW 750Li
Philips GoGear HDD6330 MP3 Player Logo
57 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
