Question about Leviton Decora Light Dimmer Switch
New Leviton 'lighted, decorative' switch flickers when off
In the process of replacing light switches throughout my house, I ended up with a flickering problem with 2 of them.  they are single pole, decorative, lighted switches made by Leviton.  also noted, in both cases I have a 'low energy' light bulbs (the ones which look like a mini-florescent).  Does anyone know why these switches now flicker when turned off, or is the switch simply bad.
Thanks, Vince
  • Samuel Charles Spriggs May 11, 2010
    I would check the connections to make sure all are tight -- it sounds like you may have some arcing caused by loose connections. (Wire nuts, plug in wires on switches, screw terminals...)
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 50 Answers
Personally, I've had no practical problem using the standard lighted switches with CFL bulbs but I am willing to put up with the flicker as the switches are in an unimportant area. The reason why they flicker is each CFL bulb has an electronic circuit in the ceramic base so you don't have to install a balast circuit in every lamp and fixture in your home. This is also why they cost more. You are basically throwing away a complete flouresent light fixture when you change these bulbs. Anyway, the reason the switches flicker is that there is a capasitor in the circuit that keeps charging and discharging through the little neon bulb in the switch. I had a CFL bug light on my back porch and when I was outside looking at the stars at night, I kept seeing something out of the corner of my eye. I stared at the bug light for a while and it was flashing every few minutes as the high voltage circuit in the bulb would charge to it's ignition threshold then fire the bulb and start the cycle all over again.
Good luck.
Posted on Feb 09, 2011
  • 704 Answers
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
Posted on Aug 07, 2009
    New Friend:
I had the same issue the Switch was blinking not the CFL lights and I can say that it is because of the CFL bulbs. When I replaced the bulbs with regular bulbs it stopped flickering. I can live with the slight flickering just wanted to make sure I did not connect some wire wrongly..
Posted on Sep 13, 2013
    New Friend:
I had this problem and this site helped (I just changed the bulb to "old style" )
Posted on Feb 15, 2017
    Problem Solver:
  • 7 Answers
I would say the switches are bad.
I have replaced several switches that have gone into the flicker mode. Problem being the neon gas escaped from the bulb over time because of a bad seal around the electrodes. Some are "bad" from the factory.
Test this by using a regular type incandescent bulb. If the switch flickers, then it's bad. Try the CFL, compact florescent bulb in another area where you have a switch like that installed and it was working properly.
It may be the electronics of the CFL do not pass enough power to the neon lamp in the switch.
Posted on Aug 05, 2009
We have Leviton Decora switches throughout our house. Some of the lights flicker, and have since the house was built 4 yrs ago. When they flicker the switch makes the same sound that it does if, when the...
Several questions here.
1) Lights should not flicker and switch should not make sound (or get unusually warm)
2) You should not have to 'press hard' to get switch to turn off.
3) Are the switches defective. YES. Remove and replace with ordinary toggle switch and see if flickering and sound-making continue. If problems continue, maybe local electrician should assess problem on-site.
4) Press to Release. You are speaking about wires connected on back of switch using 'quick-connects.'
Wire is pushed into a hole where wire is wedged against brass spring and held tight.
To release wire there is usually a hole or slot next to wire. Push small screwdriver into opening. Usually you have to push screwdriver very hard using one hand while other hand holds switch. Then use your additional hand to pull out wire. Or you can clip wire off and then strip back insulation and start fresh on new switch.
5) Builder electricians sometimes buy super cheap brand knock-offs that are not UL rated. Do not think all Leviton products lack quality. Buy new switches at local home center, and new switches will work fine.
6) When replacing switches, pay attention to screw-color that sits next to quick connect. Take a photo before removing all wires.
Screw colors tell electrician how to wire a device, and you can post new question at fixya, or add a comment for specific help.
7) Resources:
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical switches or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 04, 2011 | Leviton White Decora Rocker Switch &...
We have Leviton push button slide dimmers w/the locate lights for power outlets and lights throughout our house. A couple of months ago one stopped push the button to turn it on and it...
Wiring is not best suspect.
If all the Leviton devices were installed same time, they may be failing at same time due to lifespan.
For example, ordinary on-off switch is a mechanical device with mechanical parts, and mechanical switches last many years longer than wiring devices that have electronic parts.
Electronic devices usually have standard 1 year limited warranty.
Jun 29, 2011 | Leviton Decora Light Dimmer Switch
I installed 2 3 way lighted dimmer switches (DR703PWV) in my Living room Chandelier, and the control for On & Off is working as it is supposed to, but when I try to dim the chandelier flickers from...
Install one dimmer at the load end feeding the light. Install a standard 3way switch at the other end. Make sure the dimmer switch is rated for the type of bulbs in the fixture. ie Led, halogen etc.
Mar 16, 2011 | Pass & Seymour Trademaster 3-Way 15 Amp...
Leviton 3-way wide view motion activated light control, flickers, then blinks then shuts off after installation. Installed in a hallway with florescent lighting.
Some switches are not designed to work with the florescent bulbs. It's a matter of them trying to push a starter for the light. Check the package and see if it's compatible.
Jan 06, 2011 | Leviton Electrical Supplies
Have 3- 13 watt mini spiral bulbs on fixture. When switch in auto mode, lights hum, flicker and not maximum brightness. When switched to on position, lights stop flickering and humming. Full brightness as...
-Replace the compact florescent bulbs with regular incandescent bulbs and see if problem continues.
-Lighting controls are made for different kinds of bulbs.
-Your package should say what the watt rating and type of bulb.
According to the PR180 manual:
-I am looking at the Leviton PR180 occupancy sensor manual, and the PR180 sell-sheet, and these documents say for incandescent and fluorescent (rapid-start magnetic ballast only).
-Compact fluorescent are supposed to have a magnetic ballast.
-The manual does not specifically say it works with 'compact fluorescent'
-The manual does not say there is a minimum amount of wattage either. Some controls will not work correctly if the overall wattage is low. Your overall wattage is 39watts.
Read the product package (if this is a new installation and you have the package)
Try the incandescent bulbs.
If the PR180 is not your product, add a comment with product number and I'll look for information
Nov 06, 2010 | Leviton R01-PR180-1LI Decora 180 Degree...
Need to replace the light switch in my bathroom.
If the switch has only two terminals besides the ground, then yes, they are equivalent. BUT, do you have a ground wire? If this is an old house without a ground wire you have been lucky with the metal faceplate, especially in the bathroom. The new switch is no more dangerous without a ground wire than the old one was, but there is a reason they put that ground lug on there. If you don't have a ground wire, get a plastic faceplate.
May 15, 2010 | Leviton 1451-2ACP Grounded Quiet Switch
Leviton Dimmer Switch wiring and ceiling wiring for new kitchen table light fixture
I recently purchased a Leviton Dimmer switch which has a brown lead. This switch is to replace 1 of 2, 3 way switches that control the ceiling light in my kitchen. My problem is the new dimmer switch has 4 leads including a brown one which has me confused. I have installed and replaced numerous dimmer switches without difficulty. Please help.
Oct 10, 2009 | Leviton Decora Light Dimmer Switch
Touch dimmer malfunction
sounds like a loose connection to me, check to make sure all connections are tight. sometimes the bulbs themselves don't make a good connection in there socket.
u will have to take the switches out of the wall box and make sure the wires are tight, whether they are on screws or wires connected to wires. if it is wires to wires u may have to take that apart to make sure u don't have a bad connection there.
if it is none of that, then it is time to replace the switches
Jul 04, 2009 | Leviton Decora Light Dimmer Switch
Leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
Nov 02, 2008 | Leviton Decora Light Dimmer Switch
Leviton  Decora Light Dimmer Switch Logo
5,518 people viewed this question
Top Leviton Electrical Supplies Experts
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
