Question about Filter Queen Majestic Canister Vacuum
No air pressure to **** up dirt
I have an old filter queen, from back in the 90's, and it's always worked fine. Now there isn't much suction power. I've cleaned all the dust out, taken it apart but I don't know how to increase it's power. When turned on, with clean filter, etc, it barely picks up loose dirt on the floor. What do I do
    Problem Solver:
  • 7 Answers
First test suction on unit without the hose, is there suction? If yes, attach hose and test. If no go to the door to outside, attach hose to the top of unit where it blows (under handle on top), put hose out door and turn on. The stuff clogging the hose should blow out the end.
If it wasn't the hose check the wand, and then the power nozzle and using the above to clear obstruction.
FQ Master
Your Authorized Filter Queen Service & Supplies
888-637-4692 in Iowa
Posted on Jun 15, 2009
When taking the handle/wand back to use it seems to lose the suction power regardless of what setting I use. Upon several times of standing it back up it seems to engage the suction power correctly is...
When you say taking handle back I assume you mean the action to start rotation of brushes. Had simular problem and found by removing brush from tube and then cleaning "baked on rubbish" in plastic tube (so you can see clearly through tube) Clean with stiff brush and also making sure brush drive belt housing is also clean and allows brush to rotate square to housing did improve the suction power.
I assume you have cleaned all filters by wahing under running water and applying a little pressure to remove water and attached dirt?
Nov 08, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
How do I get rid of the bad smell coming from my filter queen
Change all 4 of the filters, and wash the dirt container with soap, water and a little bleach. The only other thing that would cause a bad smell would be the actual motor, but that would be more of a burning smell. Good luck!
Jan 25, 2012 | Filter Queen Majestic Canister Vacuum
Filter queen vac 2 years old suction poor cleaned hose canister and filter
Hi, Did you change both the cone and the filter on the top lid? If so, ther may be a leak in the machine breaking the air tight vacuum. When you put it together make sure its in properly and tight. Let me know if this does not help, I will look at something else. Chris
Feb 09, 2011 | Filter Queen Majestic Canister Vacuum
How often is it necessary to change the filter one on a Filter Queen Majestic?
The best thing to do to both, keep your Majestic suction and air flow strongest, and keep from pulling dirt & dust from being pulled past the filters which can cause damage to the motor, and charcoal filter, replace the filter once a month. If you use it longer than that it will both loose suction and will cause your Medipure or Enviropure "charcoal" filters to wear out prematurely. Mark the change date right on the filter or on your calendar to help keep track.
Dec 20, 2010 | Filter Queen Majestic Canister Vacuum
It has lost most of its suction power...what to do?
clean all the filters if this doesn't help then check for blockages at head, hose and entrance to collection chamber
May 30, 2009 | Vacuums
Filter Queen, carpet attachment problem???
Open it up and see if the dirt inlet is clogged. It would be by the brush roll. But you must have a clog.
Mar 09, 2008 | Filter Queen Majestic Canister Vacuum
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Attachment hose has no suction
Sometimes when you take them apart and
reassemble the vac (the plastic slide doesn't
make full contact with the lever,or it isn;t on
the lever at all) that switches
from the floor to the attachment. IF Tthere
are no clogs in the duct then that the
most likely problem
Nov 18, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Filter Queen Majestic Canister Vacuum Logo
279 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
