Question about LG 50PC1DR 50 in. Plasma HDTV
It makes a weird noise when trying to power on then shuts down
It makes a noise when trying to power on then won't turn on
  • azdevelopmen May 31, 2009
    still has power but squeaks for 3 or 4 seconds then goes back to rest mode. Satellite power still works as well as stereo components
  • 822 Answers
Check prower supply.
Posted on May 31, 2009
Computer won't boot
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 26, 2012 | Computers & Internet
My 2000 4runner started to make a weird noise by fhe fuse belowon the left of the steering wheel after I try to close the windows there where no power and to lock the doors from outside nothing no power I...
Not sure here to be honest as it could be a connection terminal arcing but without a look myself i couldnt say as its not a fault i come across often
Mar 08, 2012 | 2000 Toyota 4Runner
Makes a weird noise when you turn the ignition to start. It has been doing this for a couple of weeks and now won't start.
That weird noise is starter gear clashing with the flex plate gears, change the starter and hope it works.
Sep 19, 2011 | 2004 Chevrolet TrailBlazer
The air conditioner stopped blowing air. It is still too hot for it to have shut off automatically, When I power it down & turn it back on it makes a noise but won't start blowing the cool air. The...
Your going ot have to shut it down and let it deice. remove the filter and replace it or wash it out . this might take a few hours so leave the indoor fan on it will speed thing up a bit. also set the temp to mid range and close all unused rooms off it has to cycle a bit but really my money is a dirty filter and ice.
Jul 19, 2011 | Heating & Cooling
Ps3 slim 129 gb will mot eject mw2 it makes the beebing noise and the another weird noise that sounds like it is stuck and the doesnt work the games does eject from the main menu but it is still in the ps3
1. First shut down the system by flipping the power switch in the back off.
2. Hold down the eject disc button.
3. While still holding down the eject button, flip the power switch to turn back on your PS3.
4. When the green light comes on, wait a few seconds then tap the eject button a couple times. The fan will run on full power and the disc will eject.
Nov 23, 2010 | Sony Playstation 3 (PS3) Console
My Keurig Elite brewer is not brewing. When I turn it on, it makes this weird buzzing noise, but it will not fill with water. None of the other lights are on either. What could be the problem?
Keurig is having a big problem with this. When you turn it on, pick up the reservoir and place it back down. What you are hearing is the unit trying to pull the water through and it won't. It will try for a minute and then shut itself off. So power on, lift and lower water unit and it should be good. CALL KEURIG and tell them about the problem. If enough of us call then maybe they will do something.
Aug 31, 2010 | Keurig Elite B40 Coffee Maker
Have a 06 rca hd61w66 powers on but screen dont come on! makes a weird noise an shuts down! like sumthin is tryin to start up but cant! n i took back off tv to see an the noise comes from a boared on the...
Thats the Power Supply. You need to call a service man, please disconnect this unit from the Power, It is dangerous to leave it plugged in. what is happening is the set has developed a serious fault, to avoid a fire or explosion, the PSU has shut down the set. that noise you hear is the power supply struggling against the fault. trying to start. Please for safeties sake, get a "Quote" from a reputable, preferably an RCA recommended service centre.
Mar 28, 2010 | RCA HD61W66 61" Projection HDTV
Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Aug 09, 2007 | Frigidaire FES367 Electric Kitchen Range
LG 50PC1DR 50 in. Plasma HDTV Logo
348 people viewed this question
