Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi tv model ws-65315, when i turn the set on, the green light comes on for a second then the set turns off what could it be
    Problem Solver:
  • 4 Answers
Check the voltages at the test points on the power supply. If the voltages are correct and all the fuses are fine, check for swolen capacitors on the format and the DM boards and replace them
Posted on Jun 01, 2009
When I turn the tv on the power light goes green for a couple of seconds then it shuts off and the picture never comes up.
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Jun 03, 2011 | Mitsubishi WS-65315 65" Rear Projection...
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
MItsubishi HDTV 1080
need to call a servicer, if they found out that if this is a chassis issue, call mitsu
Sep 20, 2009 | Mitsubishi WS-65315 65" Rear Projection...
I have a mitsubishi 1080 series wt-42311 model. When I turn on the TV the green lite comes on then goes off? The TV wont turn on.
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Sep 18, 2009 | Mitsubishi WS-65315 65" Rear Projection...
My tv model ws65315 green ligth turns on and then turns off and the screen doesn't turn on
The TV probably has the -27 volt fuse blown. This fuse will blow when your convergence amp IC's have gone bad (STK-392-250)
Call a good TV Tech.
Jul 30, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Tv won' turn on. Green light constantly blinking.
this tv is mitsubichi?
is mit what is the model?
look like bad DM, you need chage The capacitors.
Jan 31, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Green light doesnot turn off on Mitsubish WS-65315
Just go to menu... then ..setup... then... timer ..and turn it off...... the blinking light goes away
Aug 29, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Tv mitsubishi ws-65315 doesnt turn on,only green light
Good Day, cutito35; 1. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. 2. (Power LED may be on after plug in) check for no less than 4.4 volts DC at pin 3 of PC9A21 on the Power PCB, if low or missing replace PC9A21 part # 268P058020. 2.This model is also equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB. Good Luck, big IRISH.
Ws-65315 won't turn on
Need to know more, 1-2 is no error code, you say will not turn on, do it has led light on or do you hear sound in set like high voltage? Any lights blinking? Or just completely dead, like fuse blown?
Mar 24, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
574 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
