Televison & Video Logo
Posted on May 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ac adapter Hi I have a Goodmans Ld 2050-fvt but i have no ac adapter do you know the voltage pin outs Regards George
Ekse
Level 3:
  • Master 13,435 Answers
  • Posted on May 31, 2009
Ekse
Master
Level 3:
Answers
13435
Questions
82
Helped
3984754
Points
38023
Hi
I will get back to you within 3 days or sooner when I have the details for you or a place to purchase a new adapter.
thanks and sorry about the delay.
Ekse
  • Ekse Jun 03, 2009
    Still haven't heard back from goodmans, you can repost the problem with the button that you have somewhere over there if you don't want to wait for a answer any longer. another expert will help you,
2helpful
2answers
I need to know the POLARITY of the AC adaptor to provide the correct setting using a universal adapter.
there is no polarity in ac current as ac means alternating current and that means alternating between positive to negative back to positive back to negative and so on
only dc ( direct current ) and the center pin of the plug is designated as the positive pole has polarity, the outer case being the negative
OR Are you asking the voltage of the ac adapter and the voltage of the dc output side of the adapter
Power problems
Unplug the AC adapter (Charger) from power. Unplug the AC adapter from the laptop.
Remove the Battery.
Press the Power On button in, and hold it in for a count of 10 seconds.
(And I mean 10. Count, 1001,..1002,..1003,..etc)
Reinstall the Battery. Plug the AC adapter back in. Plug the AC adapter into power.
(ALWAYS plug the AC adapter into the laptop FIRST, then plug the AC adapter into power.
Why?
To avoid a voltage spike at the laptop)
WAIT 1 minute, turn the laptop on.
Still no?
Then the AC adapter needs to be checked, to see if it is putting out the correct voltage.
Don't know, Model Number wasn't stated.
AC adapter checks out, then it is on to the DC Power Jack.
The jack on the laptop (DC_IN) that the AC adapter plugs into.
What style?
Don't know the Model Number wasn't stated.
DC Power Jack checks out, then I suggest you have a problem with a Power MOSFET,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
(Model Number is on the Bottom of the laptop. Plus, this IS a Dell, right?)
Post back in a Comment.
Regards,
joecoolvette
1helpful
We have an Acculab V-200 electronic balance here at school. The AC adapter was misplaced, however one with a 12 volt output was found. It fits the balance but I am afraid to plug it in since the unit can...
re: Acculab V-200 Digital Scale
The original AC acpater is rated at 12VDC 300mA output. It is unregulated (i.e. the output voltage is about 16-17V with no load)
The centre pin is NEGATIVE, which is the opposite of "most" AC adapters.
(Acculab model number is 41-12-300D, for the 120V 60Hz version)
3answers
The pin broke off in my AC Adapter. Is there
Unforturnatly you cannot just glue back on the pin from your ac adapter.
but you can buy just the "brick" part of the ac adapter and should be less than $80.00 for the complete set.
Hope this helps.
49helpful
2answers
Vec010bd AC charger part # 5140045-34 question . . .
barrel pin 12v 500Ma is correct. the only other required stat that you need to know is that the polarity is( ---------that's how the inside pin polarity is shown on the transformer. Go to any radio Shack, and they have this charger in stock. tell them you need a 120v. a/c input, 12v. DC 500 ma output, with the center (inside) pin positive( ).It should be less than $20.00
1helpful
2answers
Power Cord
Please let me know when I can get the power cord & AC adapter. I moved and lost them and cannot use my television. Thank you R. Werkheiser
16helpful
3answers
Mikomi TV power pack/transformer/AC adapter replacement
Power Plus Online sell a replacement ac adapter 'PSU 1' at www.power-plus.tv we purchased one recently for £29.95 and this works fine.
Regards Steve
2answers
Toshiba Portege 7100 AC Adapter
all are not same but you buy through ebay you cant replace it go the shop and verfy onces
2answers
Evesham Nac-cam 7000
Hi
We sell the chargers for the unit. we bought all the stock when evesham went down they are 100% the right one
username on ebay whenitssolditsold
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
