Question about Whirlpool GEW9250 Electric Dryer
Dryer is not working. You cannot hear engine working when machine is turned on. Dryer is not starting and I do not her the motor when the dryer is set to work. I have checked cord and fuse box - ne
Dryer is not working. You cannot hear engine working when machine is turned on. I have checked cord and fuse box - neither seems to be the issue.
  • 6,784 Answers
CHECK THE FOLLOWING--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Timer
Replace if defective (note: uncommon problem).
Posted on May 31, 2009
My dryer turns on, but will not spin. I can turn it by hand, and it is clicking like it is trying to work, but it won't turn.
It could either be your motor capacitor which is the more common item, or the actual motor itself.
If you start the machine and can hear the motor running but no action, that is your drive belt. But if motor is struggling to turn it is your motor capacitor which basically kick starts the motor.
I am not familiar with the Samsung dryer as I have not seen them. Not sure if you are able to hold in the door switch with a screw driver and then start the machine. If so try this and turn the drum by hand. If this makes the dryer run after the initial jolt, then it is definitely your motor capacitor.
Sometimes the capacitor is inbuilt into the main control board.
Good luck.
Ash
Sep 02, 2011 | Samsung DV419AGW Dryer
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
The machine will not start. You hit the power button in comes on, but when you press the start button -- nothing happens. You can hear the clicking while pressing it - but it doesn't start drying.
heatman101
Apr 23, 2011 | General Electric GE DBVH520EJWW Electric...
Drum not turning on spin cycle but i hear motor spinning
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Nov 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
WONT START CAN HEAR TIMER RUNNING DOOR BUTTON WORKS MAKES START BUTTON RESET CAN HEAR IT RESET BUT NOTHING HAPPENS WHEN I HIT THE START BUTTON
heatman101
Nov 14, 2010 | Dryers
I have a whirlpool duet dryer control panel works but it will not start all I hear is a click. Motor turns freely
heatman101
Sep 24, 2010 | Whirlpool Dryers
Hi - I have a 500 series Gas machine that willl not start. I can hear the timer clicking but it wont start.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Kenmore 500 6952 Dryer
Dryer just stopped working can hear the timer but otherwise dead
heatman101
Aug 18, 2010 | Maytag Performa PAV2200
Dryer start button doesn't work
door switch or possibly the motor. if you hold the door switch in and push the start button have someone turn the drum by hand if it starts running it is the motor
Jul 04, 2010 | Frigidaire FEX831CS Top Load Stacked...
We hear the engine start but do not turn the big cylinder
The dryer has a belt running around the drun so it will turn is. It also has a belt tensioner to keep the belt tight. The tensioner has either a broken roller or the belt has broke
Feb 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool GEW9250 Electric Dryer Logo
83 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
