Question about Canon PIXMA iP1700 InkJet Photo Printer
WON'T PRINT BLACK
HAVE REPLACED CARTRIDGES HAVE GONE THROUGH CLEANING MODES
    Genius:
  • 1,018 Answers
Are you using a Canon factory new cartridge?
If you are using a refilled or third part cartridge, that is most likley your failure.
Canon does not support or warrant the use of these types of products on their equipment.
Don
Posted on May 31, 2009
  • 44 Answers
Check your printer settings it may be set to print color only hence the non black print capability
Posted on Sep 30, 2009
Cannon Pixma MP780 won't print. Just replaced black ink cartridge, do I have to replace all of them for it to print
Not normally but the black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 08, 2013 | Canon PIXMA MP780 All-In-One InkJet...
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
Canon Pixma ip3000 will not print in color. We recently replaced all three color cartidges and when I went to do a nozzle check, it only printed the black part of the test page. Several times. I went...
I find this an unusual problem but lets look at the logic.
It worked ok before your replaced the colour cartridges.
Your replaced only the colours and now it does not.
Did you replace the cartridges with like for like?
Are they compatables? Did you run the cleaning cycle?
Run the cleaning cycle at least 3 times.
If still no good buy 3 genuine canon cartridges and see what happens.
If still no joy then must assume the printhead is the problem.
A bit of a coincidence?
Aug 11, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
My Brother LC61, bought in Nov.2010, won't print black. Recently replaced black ink along with all color inks...replaced black ink again when it quit printing...still won't work. Machine whirs...
This is common problem with Brother Printers. I am going to assume you are using Non-Brother branded ink cartridges. Brother cartridges have a cleanser in the ink that most generic cartridges don't have. This in turn causes the jets to clog and not allow ink to pass through them. The fix is to go buy a couple of Brother cartridges and do a cleaning with those cartridges. You may spend some money doing this as a cleaning wastes a lot of ink, but it will clean the injection lines and fix the printer. You could also consider buying a new printer. I know this is not the answer you were looking for, but it is the true answer. I just bought a new printer due to this fact.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Brother Multi-Function Center MFC-240C...
Won't print black
Kindly reseat the cartridges 2 times and then close the access door .Click on Menu on the printer and scroll down and choose Clean printhead and select "deep cleaning"
Print a demo sheet after the cleaning process has been completed. If ur issue persists, Call Kodak @ 1800 421 6699 and they will replace printhead of the printer free of cost.
Printhead is the part which takes the ink out from the cartridges. It seems that the printhead of the printer has gone bad.
Nov 26, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Cartridges replaced,not printing colors
Are you using compatible cartridges? If so have you used them before?
Make sure that you run a cleaning cycle in the printer and then print out a test sheet to see if there any issues. You may have to run the cleaning proces 2 or 3 times to get it working properly.
Sep 12, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
My black ink in my PIXMA MP760 printer will not print. I have gone throuh the maintenance process for cleaning and deep cleaning the heads and it still will not print any black whether it is text or...
The print Head has gone bad. Not using a printer that often will dry out the print head. The print head is where the ink goes. Try to get a cue tip and put some Alcohol in the place where the ink goes through. These should be small sponge like things underneath the ink cartridges.
Jun 06, 2008 | Office Equipment & Supplies
Document fails to print
Power the unit down for an hour or so. If still a problem
Uninstall the software and then reinstall software from the CD.
Mar 27, 2008 | HP PSC 2110 Color Printer
HP Photosmart 7550 printer
There are some print head cleaning modes you may want to try.
In your menus , look around for those and run the print head calibrations and cleaning procedures.
Also with the printer unplugged. Dampen an cloth with some rubbing alcohol and remove the print cartridges, lightly clean all the contacts with that damp cloth.
They may just have some ink on the contacts giving you a false failure message.
Hope this helps you out. They can be fickle.
Dec 14, 2007 | HP PhotoSmart 7550 InkJet Printer
Open Questions:
See all Canon PIXMA iP1700 InkJet Photo Printer Questions
Canon PIXMA iP1700 InkJet Photo Printer Logo
148 people viewed this question
old marine
old marine
