Question about Infinity BASSLINK Car Subwoofer
Humming noise when amp is powered on.
My infinity basslink simply hums when plugged in. Occasionally it will pick up a signal from the head unit and play very distorted low tones. I have checked the connections and even hooked it up through line out connections rather than the speaker wire connections that it was originally hooked up with. Still, the humming continued. Could this be a blown coil or a blown amp? all fuses are good. What should I do?
  • 378 Answers
Check the heatsink, touch it with your finger feel it ,if you can hold it with in 15 sec, then your power amp. component might be working if not then probably you Power Amplifier IC or transistor is shorted.
Posted on Jun 01, 2009
My cars battery died, and when i turned the car on finally the head unit and my infinity bass link didnt turn on
Check the fuse in your car's fuse panel. If it is burnt then change. If it is still good, check the fuse on the head unit and amp.
Sep 03, 2012 | Infinity BASSLINK Car Subwoofer
I have a 2005 Mitsubishi Eclipse with the Infinity high end stock radio installed, which has a 200 watt amp under the seats. The head unit does does not have direct speaker outputs. The head is connected...
I am going to refer you to the live help
at crutcfield.com audio
They can give you ideas on compatible equipment and designs that will achieve your desires without the OBVIOUS overlad/mismatch.
Your search for comparison returned these articles
Free factory (usa market) wiring diagrams
BBB Industries Premium Alternators Starters Power Steering Products
Mar 11, 2017 | Infinity BASSLINK Car Subwoofer
My basslink circuitry is fried!!
go to the website that built the part. they usually have manuls you can download and get exact part number.. then go to ebay or google t for fix andddd parts cosr
Feb 17, 2010 | Infinity BASSLINK Car Subwoofer
Basslink
My first suggestion is to check the gain setting of the unit. If it's above the 50% point, drop it down.
Second, verify your ground connection is good, short, and solid.
Mar 15, 2008 | Infinity BASSLINK Car Subwoofer
No Sound from Basslink
Do you have speaker wiring or RCA's hooked up from AMP to Basslink? Also check the settings, make sure you are have bridged the channels on amp.
Feb 02, 2008 | Infinity BASSLINK Car Subwoofer
Basslink "Motorboating"
Good evening, my name is Colmen here is a guy that might be able to help you 917 504 0461 please let me know how you make out, he has done a lot for me, by the way his name is Cee...
Dec 19, 2007 | Infinity BASSLINK Car Subwoofer
No power
Other than the +12V, the ground (-) and the 2 RCA inputs, normally external amps have also a remote trigger which switches it to active on. The remote trigger is activated by a wire from the head unit. Colors would either be yellow or blue but depends on manufacturer of head unit. Alternately, you can connect a simple toggle on/off switch to activate the external amp.
Additionally, pls verify that the 2 RCAs from your head unit are audio out and not audio in for aux source.
Good luck and kind regards.
Nov 01, 2007 | Infinity BASSLINK Car Subwoofer
Basslink drops out.
The auto on switch should only be in the on position when the REM wire is NOT connected. Auto on can be flaky. Basslinks respond better to RCA inputs then the high level ones. You might try getting an RCA line converter, they work very well with the Basslink.
Oct 02, 2007 | Infinity BASSLINK Car Subwoofer
Humming from speakers when CD player running
Yes, The humming is always there you just can hear it better when the cd is playing. The humming is caused by the electrical system in your car. There is an inline filter you can buy and insert it between the car's power source and the head unit. I had a head unit I bought that was absolutly terrible until I installed that filter. Also if you did a do it yourself job on your amp wiring it is usually best practice to run your RCA cables on the opposite side of the car as your power cable. You can also purchase shielded spark plug wires which is a source of noise usually of a different kind tho. First make sure you have a good ground. This means that you have grounded your amp to bare metal not painted metal. If that didn't work put in the inline filter on the head deck as they are only $20 available at radioshack. If that doesn't work, go back an wire your car right this time and put the power and RCA on opposite sides of the car. If you still have that hum it may be the spark plug wires but that sounds more like static than hum. You have a text book case of alternator hum... Hack
Jul 11, 2007 | Xtreme Sound WMS336 CD Player
Loud humming noise from subwoofer
if it is a powered sub you should lift the ground. you can do this by adding a three prong to two prong adapter. you know, like when you go to plug something in and the cord your plugging in has three prongs and the outlet your plugging in to only has two. it doesn't have the hole for the ground so you go get a little grey adapter that has three holes on one side and two prongs or tabs on the other.if that doesn't take the hum out (actually, is keeping the hum from getting in) you have a problem with the amplifier.
Aug 23, 2006 | Jensen JHT525 System
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
414 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
