Home | Magic Chef | CYE4000AWW Electric Dryer | When I push the sta...
Magic Chef CYE4000AWW Electric Dryer
Problem for Magic Chef CYE4000AWW Electric Dryer
When I push the start button it will not turn on got power to dryer
By s_keillor on May 31, 2009
Its got juice going to dryer but when I push the start button it will not kick on
Comments:
May 31, 2009
- The motor does not turn,tested the door switch its fine,timer works,got 220v at the wall plug
May 31, 2009
- check the connection at the motor?What is a way I can check the motor to see if its bad/
May 31, 2009
- Thanks very much I will try that.
Clarification Request
Posted by scspriggs on May 31, 2009
Does the motor turn at all when you push the start button?
Solution #1
posted on May 31, 2009
Not Rated)
scspriggs
Rank: Guru
Rating: 91%, 589 votes
The start button goes directly to the motor to energize the start winding until the centrifugal switch in the motor energizes the run winding.
If the motor is not trying to start, I would next test the start switch & related connections.
Comments:
May 31, 2009
- Start switch:
If you have a multimeter you can see if you get 120 volts at the end of the start switch (at the motor) when pushed -- this will confirm the start switch is good. Or, you can remove the start switch and test it for continuity when depressed.
Motor: (If you're going to be working with the motor, remove
the belt first.)
If start switch is good, you can disconnect it from the motor and jump 120 volts to the motor terminals -- if the start switch is getting 120 volts to the motor (in the above test), this is a redundant test, but it wold confirm the motor needs work.
May 31, 2009
- Okay, please let me know what you find.
thanks...
Charlie
P.S. Remember the door has to be closed when you are testing for voltage at the motor.
Was this helpful?
Yes
No
Popular Solutions for Magic Chef CYE4000AWW Electric
Questions and Unsolved Problems for Magic Chef CYE4000AWW Electric
Do you recommend Magic Chef CYE4000AWW Electric Dryer?
Answer
Answer
My dryer stopped working during a cycle last night and won't start again. The light is no longer... (More)
Answer
How do I replace the fuse in a Magic Chef microwave that is part of the oven.
Answer
Hi. We have a magic cheif dyer. It turns the clothes, but it doesn't dry. Also, it has been having... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Magic Chef CYE4000AWW Electric...:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14193
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
