Question about Canon PowerShot A80 Digital Camera
Will only work with 1.5V battery output instead of 1.2V
Canon A80 will only work with batteries giving 1.5V. Should work with rechargeable batteries at 1.2V output
  • mikej_wells3 May 31, 2009
    Have several sets of NiMH and same with all, will only work with new Alkaline batteries giving 1.5V output, which doesn't last for long at 1.2V camera will not work which Canon says it should.
  • Canon Master
  • 4,738 Answers
How old are the rechargeables? Also, am assuming you are using NiMH and not the inferior low-power NiCads. Rechargeables NiMH really aren't meant to last more than a year or two, regardless of how often they were recharged. If the batteries are older than a year, suggest trying a new set.
Posted on May 31, 2009
My headlights dont work on my sonic 50 could it be the voltage regulator
Hi, Keith if your headlight is not working the first thing to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply to headlight bulb socket.
2. Faulty hi/lo beam switch.
3. Faulty ignition switch.
4. Fuse is good but no continuity on both sides.
5. Faulty wiring between battery positive and headlight bulb socket.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
DOWNLOAD 2006 Aprilia Sonic 50
Aug 23, 2012 | 2006 Aprilia Sonic 50
Batteries run out fast
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 25, 2012 | Canon PowerShot A80 Digital Camera
It wont charge
You can't charge the A80 by plugging in a USB cable. The cable is for downloading photos only. Assuming that you are using rechargeable AA batteries, you need to remove the batteries and place them in an external charger to recharge them.
Sep 03, 2011 | Canon PowerShot A80 Digital Camera
It won't work with rechargeable batteries, but does work with ordinary batteries...hmmm?
Rechargeable batteries are rated 1,2V while ordinary one's use 1,5V. Thats why.
Nov 25, 2010 | Brother P-Touch 1180 Label Printer
Can i charge the batteries insitu on my canonpowershot A80 camera using only a USB lead and charger
No. The A80 is not a battery charger. If you want to use rechargeable batteries with the A80, you must recharge them outside the camera using a separate charger.
Aug 16, 2010 | Canon PowerShot A80 Digital Camera
LCD screen doen't display the view
So camera doesn't give live view to take picture? and you can view old / stored  pictures OK, is it?
If yes, then it is problem of CCD imager in Canon A80 and this part needs to be replaced.
Canon will repair your A80 free of cost as per announced scheme of CCD imager support.
Click Canon CCD Advisory to know how to get free repair facility.
Jan 07, 2009 | Canon PowerShot A80 Digital Camera
Powershot A80 problem: green and red lights around subject
Hello
Recharging the batteries seemed to solve it. Although I had not received the low battery warnning and this phenomenon had not occurred at other times when the batteries were low, it seems to have fixed the problem.
Thanks.
Jun 29, 2008 | Canon PowerShot A80 Digital Camera
Battery Problems
Have you tried a new set of batteries?
Oct 06, 2006 | Canon PowerShot A80 Digital Camera
Canon PowerShot A80 Digital Camera Logo
124 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
