When I ride my street glide the battery is good ,but after so long the battery discharges?
SOURCE: 2007 Street Glide shuts off between 4 - 10 miles
I believe there was a recall on the 2007 for exactly that problem (something to do with the clips breaking on the fuel line causing that exact problem).
SOURCE: 2007 street glide misses and wonts to stall out when taking off??
my roadking just did the same thing, check the gasket between carb and intake
SOURCE: 2001 hd sportser 1200 xl custom...new battery
Rob has a fine point, very good solution indeed. If your certian it's drawing when the bike is off I would suggect the same thing. Also just an FYI, Sadly there are actually alot of dealers that don't test charging systems correctly and they should have checked for a Milliamp draw. You should have no more then 300 milliamps when the bike is off. Rob's solution (if it is detected, and can be done with a multimeter following the manual) locates the draw. /me add's robs answers to favorites.
SOURCE: Voltage Regulator Problem?
u want to chec alternator as well-ther r test u can do so buy a clymer manual which r very detailed-iv seen hd books in library sec 629
SOURCE: Battery good, regulator good, stator good, battery won't charge
you have caused a wireing fult thats all, it likely to be a bad earth on the bars or you may have blown a fuse by shorting some thing out when you were doing the work start checking the wireing out with a meeter start from the regulator you should have volts from there back to the battery check for a main fuse as well
