Question about Dell Inspiron 1300 Notebook
Bettary problem or adaptor problem?
My inspiron 1300 is having problem with battery. one day i used it with out AC connection n the battery was fully discharged, then kept it for charging it up but it was not working, the green light was blinking but battery wasn't charging then it started to blink red light. i replaced the battery. now even though the battery is fully charged but still the green light was blinking after some time it started to blink red light. i took off the AC connection battery is fine working.n even if i take off the battery it works with direct AC connection. but why is the light blinking? plz help me out
    Champion:
  • 220 Answers
Ac/dc convertor board inside laptop faulty.
Posted on Jun 30, 2009
Hi. I have an Inspiron 1300. Suddenly, the screen ...
Black screen is often caused by a defective screen. The easiest way to determine if you have a hardware or software problem is by performing a power drain. Please follow the steps below for additional instructions.
Power Drain:
1. Turn off the computer.
2. Unplug the AC adapter from the power outlet and take out the battery from the system.
3. Now, press the power button for about 15-20 seconds.
4. Put back the battery in and plug the AC adapter.
5. Turn on the system and try observing it.
--> If power drain did not work, you need to consult a repairman to have your screen be checked for possible damage.
Hope it helps.
Thank you for using FixYa.
May 21, 2010 | Dell Inspiron 1300 Notebook
Inspiron 1300 PC Notebook: I can not start my Dell Inspiron 1300 , when i plu...
adapter should be fine..if light comes on adapter should be good...leave battery out of the system...just use adapter and when starting system up tap f12...see if u can see this menu..if not try a external monitor to see if u can get a image..if so run the diagnostic..if still no image or no external monitor it may be a mb
May 06, 2010 | Dell Inspiron 1300 Notebook
Inspiron 1520 Power Fault?
dead motherboard, highly likely to be fine if the battery is full
Aug 01, 2009 | Dell Inspiron 1525 Notebook
Inspiron 1300 battery
If you have replaced the battery with a NEW one and it doesn't charge, then you either have an issue with the AC adapter (If the sensing pin is bent or broken in the barrel of the connector, the battery will not charge) or the charger curcuit of the motherboard. If the issue occurs on a different AC adapter, then FLash the BIOS to current version. If battery still doesn't charge, then replace the motherboard
Jun 24, 2009 | Dell Inspiron 1300 Notebook
Dell inspiron 1300 wont work from the AC adapter
Is the laptop working without the battery, directly on AC. Have you tried using another charger or battery to see if its charging.
Jan 28, 2009 | Dell Inspiron 1300 Notebook
Wont power up
the vr\ery first thing what u have to do is that disconnect the ac adaptor and take the battery out of the computer and then press and hold down the power button without the battery and the adaptor for one minute and then connect the ac adaptor and put the battery back in and then try and turn it on and what u can do is that try and turn on the computer only with the battery and then take the battery out and try and turn it on only with the adaptor,and then what u can try is that try with the different adaptor having same configuration,and try and connect the ac adaptor into the different wall outlet....good luck
Jan 28, 2009 | Dell Inspiron 6000 Notebook
No Power : Dell Inspiron 6400
the very first thing that u can try is that try with the different ac adaptor and the battery if u have and if it doesnt the same thing then definately u have to replace the motherboard and if the other ac adaptor and the battery works then replace the ac adaptor and the battery but what i suggest u is that u should replace the ac adaptor and the motherboard both at a time and it will be fine and for that u dont have to worry about ur data in the computer cause replacing the motherboard will bot loose ur data.......
Jan 25, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Ac adaptor use drains batteries
As a system gets a little age on it, the battery naturally decays. Also, each time you plug the ac adapter into the laptop, the adapter connection on the motherboard becomes a bit looser on the solder points, all of which contributes to the symptoms you describe.
You could try a fresh battery.
The standard rule is a battery is wireds to last between 500-600 cycles, then it's dead. They claim it's a safety feature.
Good luck, hope that helps.
Thanks
Jan 31, 2008 | Dell Inspiron 1000 Notebook
Dell inspiron 6400 battery pack problem
If your battery pack does not charge and power is being supplied by the AC adaptor to the computer then i would guess the cells are dead or maybe the connection to the battey has been damaged in some way. The best way to check is take it to a computer repair shop or spares shop and ask them to try it with a new battery if the same problem occurs then it is the connection or the ac adaptor. My solution would be try a new battery before you buy it to check if it is the problem.
Jan 29, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 1300 Notebook Logo
840 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
