Question about Frigidaire FAM186R2A Air Conditioner
I need to know if this model ?FAM186R2A? can be turned on with a timer.
  • kay5723 Jun 01, 2009
    I don’t have this air conditioner so I can’t try it. I want to buy it but before I do I want to know if it can be turned on with a timer.
    thanks for trying
    President:
  • 1,489 Answers
I doubt a timer would work because it has electronic controls which would require manually setting the A/C when it is powered up.
You can test the concept by setting the A/C where you want it to come on if you had a timer, unplugging the unit for a few minutes, then plugging it back in. If it doesn't start up where you left it before it was unplugged, then a timer will not do the job you want it to do.
If it does come back on where you want it, a good timer to use for that unit would be an Intermatic hot water heater timer.
Posted on May 31, 2009
  • Samuel Charles Spriggs Jun 01, 2009
    This rating is a "thanks for trying", so apparently you didn't like the answer. What did I miss?
    Thanks for the additional info -- that would have been helpful. I agree you can't test it if you don't have it.
    I doubt a timer will work. But I can't promise that -- you could call the manufacturer, but they probably wouldn't have a clue.
    You could run the test I suggested on another unit, but other than that, I don't have any suggestions.
How do I set the time on my Westinghouse TM201, two outlet timer, and then set the time I want the lights to come on and off?
I believe with that model you have to kill the power and reconnect by unplugging you will be met with a flashing screen this is where you can set timer....
Dec 02, 2014 | Hardware & Accessories
My Frigidaire ac wall unit will not come on when I press the power button. Model # is fam186r2a. It has power
It could have a defective switch, thermostat or compressor. Any of these would cause the same symptoms. Also a loose wire at a connection point.
Jun 06, 2014 | Heating & Cooling
Defrot timer biometal
Kenmore Model Numbers Look Like 795.513012
Turn the timer slowly clockwise until the compressor and fans stop. Leave the timer alone in that position that turned the compressor and fans off for up to 35 minutes. In the first few minutes after the timer turned fans and compressor off you should be getting defrost. If timer comes on by itself and you have defrost results the timer and defrost heater are good. If the timer does not turn the refrigerator back on but the defrost took place then replace the timer. Every different refrigerator or freezer has a different amount of time on for cooling and time off for defrost so it is important to know what the model number is to answer the part number and time off/on ratio. What is the model number of the refrigerator that the timer is on? Sea Breeze
Jun 30, 2013 | Refrigerators
How do I wire a 24 hour timer
You posted under GE box-type electro-mechanical timer.
If this is not your timer, then add a comment with clear description of your timer.
GE box-timer wiring appears on following link.
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
I don't know why GE has so many different model numbers with the same wiring and programming instructions and exact same Load capabilities.
I do know some of these GE timers are prone to running fast, and maybe different models have improved circuit boards or timing clocks.
Caution: set dip switches before applying power to unit to avoid damage to timer.
Wiring on page above uses the NO terminals.
NO terminals are 'normally open,' which means these terminals turn ON only when timer turns ON.
NC or 'normally closed' terminals are ON at all times EXCEPT when timer turns ON.
When timer turns ON, the NC terminals turn OFF.
These GE timers can be wired for a wide variety of uses not shown on link above.
They can control multiple Loads in 120 and 240, and can control 24 volt loads.
However, they are not made for 3-phase.
If you add a comment with specifics of your wiring requirement, I will help more for free.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 05, 2011 | General Electric GE 56941 24-Hour Outdoor...
We need clear instructions for setting the timer
Woods makes several outdoor timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
Nov 26, 2010 | Woods Outdoor Lighting Timer
I need the serial number for my Fridgidaire FAM186R2A AC
Yes the front cover is the same as the grille.
You should see the plate with the serioal and model number on the chasis after you remove the grille.
Good luck.
Jan 30, 2010 | Frigidaire FAL126L1A Air Conditioner
Where is Fridgidaire serial number -air conditioner
If you remove the outer cover and look inside there should be sticker with the serial # on it
Jan 29, 2010 | Frigidaire FAL126L1A Air Conditioner
IMy freezer is not getting cold enough anymore
We need to check to see if your freezer is defrosting properly. I am pretty sure your refrigerator has a defrost timer located inside the fresh food compartment behind the control panel. Unplug the refrigerator and remove the rear panel inside the freezer to have a good look at the evaporator. If frozen over defrost with a hair dryer. Then let me know so we can test the defrost heater and thermostat. Your model shows a defrost timer and that is the most likely reason if you find the freezer evaporator coils frozen over. See if you can locate the timer first and turn the timer slowly clockwise until compressor stops. Wait 25 minutes and the timer should turn the compressor back on. If it does not the the timer will need replaced. Let me know what you find, Thanks, Sea Breeze
Jul 22, 2009 | Refrigerators
Frigidaire FAM186R2A Air Conditioner Logo
205 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
