Question about Nikon D70s Digital Camera
Nikon lens 18-70
My lens is stuck and will only move alittle, if forced it can be made to go up to the70mm
    Novelist:
  • 150 Answers
There must be dirt or grime in the lens rotator. You'll want to get it professionally cleaned or if you are comfortable with doing it yourself, you can use a very small amount of air, but be careful as the air can emit water because of the high pressure can or air compressor used. All the equipment needs to be carefully tended to.
Opening the lens and cleaning it is really out of the question, once the seals are broken, the lenses are now mis-aligned.
Posted on Nov 23, 2007
SOURCE:
I dropped my Nikon s205 while it was on and now it won't turn on and the lens is stuck out.. I tried charging it and nothing happens ugh
Did you try to remove the battery? and replace it.
If in the fall, the lens barrel was hit, it could be it is stuck or moved, so the position sensor can't make out where it is. It also could sit tight, so the motor is not strong enough to pull it back in or drive it to the complete out position. It looks to a repair job for a Nikon certified repair centre, but a repair like that could cost more then a new camera. So if you can't get the lens out or in just a little yourself but just with a little force moving it, I think you should start saving for another camera.
Sorry I can't help.
Perhaps is you live close to a photo store one of the staff could have a look. (just for a second opinion) Don't buy a new camera on the first visit in the shop.
Sep 09, 2014 | Cameras
I have a new Nikon 3100. The problem now is my 18-55 zoom lens is locked and it won't move. In the manual setting and by unclicking the outer lens auto button, the focus front lens is fine. It'
Simple answer; NO! What ever you do; do not try to force anything to move and don't try to disassemble the lens. Contact a Nikon Repair Depot (found in your instruction manual or on the Nikon USA website) and they will give you instructions for returning it for a repair estimate. If it is still in warranty, there should be no charge.
Dec 31, 2012 | Nikon D3000 D3100 18-55mm
I have a Nikon D3000 SLR. My lens zoom should range from 18-55mm but for some reason it won't go past 24 (so is stuck from 18-24mm) I have tried everything to fix this, including changing settings and...
Whatever you do, don't force it. Unlike your camera, which has just a 1 year factory warranty, Nikon lenses are warranted to be free from defects for 5 years; and is likely still under warranty.
Contact Nikon Service to have the lens properly serviced / repaired. Having it looked at by an unauthorized repairer or even "messing with it" yourself could void the warranty.
I hope this helps! Please rate my reply - thanks!
Dec 18, 2010 | Nikon D3000 Digital Camera
NIKON COOL PIZ L18 LENS IS STUCK.
Do not force it - the gear is jammed. Take it in for repair. If you force the lens, it will create more problems.
Oct 31, 2010 | Cameras
COOLPIX P80 Digital Camera: my nikon camera's lens is stuck...
The lens of the camera can be retracted by mechanical means driven by gears thus sometimes likely to become misaligned or jammed. Please do not attempt to force or push the lense as it might cause serious damage, the best thing to do is to have it fixed by your authorized local repair shop and have the mechanical components checked.
May 17, 2010 | Nikon COOLPIX P80 Digital Camera
My nikon 55-200 zoom lens is stuck at full zoom
Don't force it.
Did you get dust or dirt in it?
The only solution is to bring it in for service or send it to Nikon if it is a USA model.
Nikon USA will NOT repair any gray market items.
Jul 12, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
Nikon N80 w 70-300mm G lens aperture stuck can't separate
The mechunism is jammed. Rather than force things, I would take it to a camera service shop that works on Nikon to unassemble the camera to get to the locking pins. Then they can find the fault and service the camera for you.
Jerry G.
Apr 28, 2008 | Nikon N80 35mm SLR Camera
Nikon D70s Digital Camera Logo
42 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
