Question about Digi-Tech DOD-Digitech 231 - 31 Band Per Side Equalizer Home Equalizer
My DOD Bass Compressor pedal stopped working!
My DOD Bass Compressor stopped working. The LED light comes on weakly when a cable is plugged in, even with a brand new battery. No sound comes out of the output, and the LED that appears dimly lit does not turn off when the button is pressed. Anyone have any ideas?
Where is the stop lamp or brake lamp fuse and panel for a 2007 cadillac cts?
Kevin , this is a very complex way of stoplamp control , I will post GM service Description and Operation of how they work an let you deside if you want to tackle this ! Do the center high mount brake lights work ?
The brake pedal position sensor is a resistive device used to sense the action of the driver's application of the brake pedal. The brake pedal position sensor provides an analog signal that will increase as the brake pedal is pressed.
The brake pedal position sensor receives both a 5-volt reference voltage and a low reference signal from the electronic brake control module (EBCM). When the brake pedal is pressed, a variable signal is applied from the brake pedal position sensor to the EBCM through the brake sensor signal circuit. The fuse block left rear supplies battery positive voltage to the bass relay switch through the BASS fuse. One side of the bass relay coil is permanently grounded at G402. The EBCM supplies voltage to the bass relay coil upon receiving the signal from the brake pedal position sensor. The switch contacts of the bas relay close and battery positive voltage is applied through the bas relay switch to the center high mounted stop lamp (CHMSL), and to the turn signal/hazard flasher module through the stop lamp switch signal circuit. The ground for the CHMSL is applied from G402. The turn signal/hazard flasher module then supplies voltage to the left and right stop lamps in the tail lamp assemblies that have ground at G401 and G402. For export vehicles the stop lamps receive battery positive voltage directly from the bass relay.
There could be a code stored in the EBCM - electronic brake control module - DTC B3903 Stop Lamp Relay Circuit
DTC C0278 Brake Pedal Position Sensor Not Calibrated
there are several other codes that pertane to the brake lights . you could try Replaceing the bas relay !
Fuse Block - Left Rear
In the passenger compartment, under the left side of the rear seat at carpet.
Jun 28, 2015 | 2007 Cadillac CTS 3.6L
Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
Sep 22, 2012 | Alesis DM6 Electronic Drum Set
My guitar pedal led stopped working
Try replacing the LED like I did on my tuner Pedal. Here's a link to the tutorial video i made. https://www.youtube.com/watch?v=T9LP39WmHF0
Sep 11, 2012 | Music
Dod grunge metal fx69 pedal led doesn't work
Try jacking up car and put on stands as high as poss as you could have air returning when the pedal is returned ,so jack up car pump pedal 4 times fast and hold down bleed l/h/s/first ,do 2 times then the r/h/side and then push down pedal clamp rubber flex hose over back axlewith small G clamp if pedal good do same to FRONT
Sep 11, 2012 | Cars & Trucks
Blue light Slash Wah pedal. After a few weeks the blue light has stopped coming on (I run it on official 18V adapter). Rest of pedal works fine, as before. Would love to have those blue lights working...
First thing to ty is to try it using two 9 volt batteries as a test to see if lights work.
I ASSUME that you are NOT trying to use the pedal in the external effects loop (send and return) as the levels are not compatible. The pedal must be between the guitar and the inout of the amp.
Beyond this I would open the unit and look for something loose or broken where the blue LED is located.
Sep 18, 2011 | Dunlop Manufacturing Dunlop SW-95 Crybaby...
Not sure what is wrong with the pedal but no sound is coming from it - the bypass light flicks on and off when i click the bypass but once the pedal is 'activated' it's completely dead! Help...
Common cause is weak battery (the LED is NOT an indication the battery is good as it will still light long after the battery is too weak). The second common problem is the input and output cables are backwards. The unit will pass audio with them backward, but NOT when you activate.
Jun 18, 2011 | ProCo Rat 2 Distortion Pedal For Electric...
Hello! I recently bought used Behringer EQ 700, but it's not working. Baterry is ok, the red ligh is burning, when I press the pedal, but no sound is coming through, even when its not on. What could be...
The red light means NOTHING regarding the battery condition... If battery is not new, try a new one.
I have seen several problems... some people get the cables backwards for input and output. The INPUT cable is what turns on the battery and it has to be a mono cable.
ANOTHER common problem with ABUSED pedals is that the jack used for external power adapter gets smashed at some point and cracks the circuit board near it. USUALLY the light will not come on when this happens.
Byond this, it probably requires repair. Some are easy to open and others are a bear to get the circuit board out... key is to NOT force very much when working on these.
Feb 09, 2011 | Behringer BEQ700 Bass Graphic Equalizer
Dd 55 drum machine bass pedal has stopped working any ideas please.
MOST of these use a piezo disc pickup.
Other than replacement, first try to open the case and see if the disc has been knocked loose.
DO verify that the other one with the set will trigger the bass when plugged into the bass input... they are compatible triggering wise.
Frankly, these "pedals" are really hokey... could prpbably use one from a fancier drum set with a true pedal.
Oct 31, 2009 | Yamaha Music
BassCube 12 Startup Problem
same here. happened after moving residences
Jun 30, 2008 | Cambridge Soundworks BassCube 12 Speaker
Open Questions:
119 people viewed this question
Top Digi-Tech Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Digi-Tech Audio Player and Recorder Expert? Answer questions, earn points and help others
