I have a customer with a laptop keyboard that got wet. Now the ~34QEDZC keys will not work, and the Z key is continually stuck. I have tried the drying out in the sun method mentioned in this forum with no success.
What I need now: How do I remove/replace this keyboard? I am a network engineer and electronics tech, so I am no stranger to intricate repairs. I just can't seem to figure out how this thing comes apart, and wanted to get a step by step how to for this model.
I have already found a replacement, but did not want to order it until I had the old one removed. Thanks in advance for the help.
Thanks for the quick reply. I will give it a try sometime this week. Many thanks.
As you have done, and I would suggest to anyone with the same problem, just replace the keyboard. You can get them quite cheap and in used working condition from some of the online auction sites.
Most of the Acers laptops will have a couple of screws on the bottom that hold the keyboard in, possibly. Will also need to remove the hinge/power button cover between the keyboard and the lcd. Might have some screws holding it in from the bottom, might not, also check under the battery at the back for any hidden screws. It may simply pop off and on... then you'll possibly find two screws under that holding the keyboard in. Once the screws are out, simply lift it slightly to find where the ribbon cable plugs in. And gently lift the locking latch on the keyboard plug. The ribbon will then easily slide out. And simply do the reverse to install the new one, making sure to push that plug lock back down.
This is just a generic assumption, as I am not real real familiar with the 5570, but they are all alot alike. Also note, when removing the power button cover, just in case there may be a ribbon cable under it attatching it to the mainboard, if you pop it off, look under it before pulling it too far. Wouldn't want to rip a cable if there is one there.
