Question about Carrier 52CQ-312-4 Comfort Series Heat Pump Air Conditioner
Condensor fan not running after replacement
Replaced the condensor fan motor on carrier heat pump. rewired with new capacitor and still not running. compressor is running until it reaches it's high pressure cut off point. curious of the circuit board.
  • 158 Answers
Check fan rotation
Posted on May 31, 2009
Crosley CAE12ESR air conditioner turn on but not blowing air. Only making buzzing sound. Cool and fan not working.
You can try this. Remove the cover, spin the fan by hand and see if the motor runs well after this, if so, the capacitor or motor condensor is bad or has defective wiring. Replacing it should take care of the problem. Some capacitors are split capacitors, have two values and serve both a fan motor and the compressor. In this case, the unit can be rewired for individual capacitors or the split one replaced.
Apr 30, 2015 | Crosley Heating & Cooling
Air conditioning condensor on side of house not working
sounds like you need to check your run cap it is silver in the outside unit and it runs the compressor and fan motor. Check on the capacitor what size it is and replace it for example 45+5 uf.
Sep 07, 2014 | Carrier Heating & Cooling
E4 error on screen
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
May 07, 2014 | Midea 24,000 Btu 17 SEER Inverter Mini...
Connecting replacement fan motor in HP condenser
What is the model number of the heat pump? What is the voltage that you are dealing with?
Nov 26, 2013 | Carrier Heating & Cooling
Heat pump Trane XE1000 needs new condensor motor and run capacitor
you could replace it yourself remove old mtr & cap. info. you need should be on body of each if not check unit call supply stores or local company for parts
Mar 22, 2012 | Heating & Cooling
HVAC condensor fan won't start-will run if spun.
See if it has any oil ports on the motor, if it has them they should be yellow and they are a plug.
If it does not have any oil ports, you are bqasically down to replacing the motor.
Jul 11, 2010 | Carrier 38CKC036 Air Conditioner
Fan motor runs backwards
Make sure the capacitor is connected to the start lead, not the run lead(s). Also some fans come with some wires you can switch to reverse the direction. If your motor has them there will be 4 and the label on the motor will tell you how to connect them. Let me know if you need more assistance or if this helps.
Jun 02, 2010 | Carrier 38CKC042 Air Conditioner
When the unit is in heat mode is the fan on the outside supose to run? Capacitor on outside and inside have been replace fan was running when capacitor was first replaced.
Hi, and the outdoor condenser fan should not be on at all in the heat mode unless this is a heat-pump!! So, I can see that this is a 3-ton Carrier split system and I haven't pulled up any information on it, only if I need to. But if the indoor unit runs on natural gas/propane, this would not be a heat-pump and the outdoor fan would run only in the cooling cycle. So, if it is not gas fired it is a heat-pump, and yes the outdoor unit should be up and running all year around. On a heat-pump you will have what is called a reversing valve in the refrigerant system that directs the flow of freon in the right direction for the season you are in. Most all heat-pumps will have a heat strip package installed in unit for emergency and aux. heat if compressor lets say fails. You're thermostat will have on it a selector switch, you will see on it these labels, Aux., emergency heat, auto/on/off/heat/cool. You will know from what I have just went through with you what you have. Forgive me for such a long explanation as I like my customers to understand more about there units in question. I could have just said yes or no and thanks? Doesn't work like that for me. I hope this has helped you out. One thing, If you determine this is a heat-pump and the fan is not on when in heat, you may have lost this condenser fan motor? You say both run caps. were replaced, and normally when you loose a run cap for a motor they will open internally, leak, buldge ect. So if this is taking place, if you can yourself take a look at the run cap. Also, make sure you have 220 volts to condensing unit. If not, check breaker probably a 30 amp double pole to see if it has tripped. You will have a disconnect box at the unit and inside there will also be 2 fuses. If you see only a pull out square connect, the fuses are still there but in behind the cover. If you have power and can hear the compressor come on but fan does not, I am positive you will have A faulty run cap, or faulty motor. Kill power to unit and try and slide a metal coat hanger down to prop or blade to see if it spins freely. If it is hard to turn bearings are froze up. If the capacitor seems to look ok, and the motor does spin free, It still may have open windings. Do these checks I have asked of you on power to the outdoor unit. If all is good, Stand in front of the unit and have someone turn the stat on for what season you are in. Lower or raise temp a ways above or below room temp. You should her the contactor close and compressor will start along with the condenser motor.If compressor starts and motor does not, then I would say it has failed and or cap again. When a motor is replaced, the run cap must always be replaced to!! Please get back to me and keep me posted. I will wait to hear what has happened. Good Luck.
Sincerely,
Shastalaker7
Jan 13, 2010 | Carrier 38CKC036 Air Conditioner
Carrier AC fan not working right
it sounds like the capacitor is shot there is usually a duel capacitor one side is for the compressor and the other side is for the condensor fan motor if it is bad the motor will over heat and turn off on internal overload
Aug 25, 2009 | Heating & Cooling
Condensor fan failure! will run if you spin by hand. rpne 24 2ton heat pump do they have a bad run of fans or cap
It could be the capacitor (most of the times) or the fan motor itself Put a new caoacitor and see if it runs without your help if doesn't replace the motor with the same hp and rpm and if the new one is rebersible make sure is blowing out.
Aug 08, 2009 | Heating & Cooling
Heating & Cooling Logo
242 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
