Question about Samsung HLT6176S Television
My Samsung 61" DLP Tv
We recently had a really bad lightning storm here, and after the power to our apartment was restored my Samsung TV wanted to act all screwy... It turns on and makes the melody sound like it should but no picture comes up on the screen.... And down in the right hand side where the LED's are... the Lamp LED sits there and blinks at me... then by some sort of magic the TV turns itself off and back on after about 10 seconds of the blinking LED Can someone please tell me whats wrong? ... =(
    Top Expert:
  • Samsung Master
  • 40,395 Answers
Failing power supply.
Posted on May 30, 2017
  • 3 Answers
SOURCE: samsung tv turning off by itself
I have the same problem of the set turning off and on by itself. There is a circuit in Samsung TVs that would shut it down if a very loud noise occurs in the program being watched, but I have not noticed that correlation. My problem is solved by vacuuming the back panels of the set. They do not seem to have any significant dust on them, but I think the vacuum sucks somewhat inside of the TV and does some good with the fan that is supposed to be cooling the bulb and the mirror. It seems to work for months on end and when the problem recurrs, I vacuum again.
Posted on Oct 28, 2008
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Posted on Feb 08, 2009
  • 610 Answers
power supply board is dead and needs to be replaced. very common problem.
Posted on Oct 30, 2009
  • 1284 Answers
SOURCE: Samsung dlp hls6186w, picture has darkened.
The lamp is the only thing that will cause the picture to go darker. According to the model you have the lamp part number is BP96-01472A. The noise you hear could possibly be the color wheel itself. The way to tell is when you turn off the TV the lamp stays on for about 10 seconds longer. Once the lamp shuts off if that noise goes away then it is a bad color wheel. Any noises past that would be a fan. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
Testimonial: "Thanks alot for the great info, that helped me out alot. Once again thanks to the Experts"
SOURCE: I have a 61 inch Samsung DLP. Works great except
it is configurable in the menu options. if you change there and goes back to how it was then you are probly in shop mode.
Posted on Jan 08, 2010
Inputs no longer getting signals
More common is storms wreck the cable box. But try unplugging power to everything for 1 minute. and retry.
May 04, 2014 | Samsung HLN617W 61" Rear Projection HDTV
Wont turn on but tries too come on,power light blinkink
Internal power supply failure. Was there a lightning storm in your area recently or utility work being done recently? This two things usually kill TV's and other electronics with surges when power is restored. If the set is under warranty call the manufacture, if not, call you homeowners insurance agent to see if the damage is covered w/or w.o. deductible. At least you can get something toward repair/replacement costs. Future fix, purchase and install a surge arrestor in your main AC panel for the whole house or buy a power strip with a built in surge filter/protector for your expensive equipment.
Jan 23, 2014 | Samsung PN51D490 3D Plasma TV
My tv was hit by lightning is it fixable
When tvs are struck by lightning most of them are beyond repairs and if successful they always give problems in the future.
Jan 10, 2014 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Wont power on
you could have bad power supply capacitors, what is the TV model #
Jun 26, 2013 | Samsung Televison & Video
Samsung hdtv how to know if lightning fried it
If the tv will not turn on it is safe to assume that the electrical storm did damage something in your television.
Jul 11, 2012 | Samsung 46 UN46D6000 LCD TV
Have a 61" dlp samsung tv, making a humming sound
Bad Color Wheel.will cause this and it is a common problem for DLP Samsungs.
Part number is BP96-01103A
Samsung Parts 1-800-627-4368
Jun 24, 2011 | Samsung HLR6178W 61" HDTV
Samsung 61"DLP wont turn on.
The lamp is easily removed to check if blown.If it is blown replace. If it is not, you may have a bad ballast.
Jul 11, 2009 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
110 people viewed this question
Jerry Greenberg
Jerry Greenberg
