Question about Teledyne Laars Laars Lx Pool Heater / 400,000 Btu / Propane Gas
Laars LX400P pool heater Hi Limit Switch light is on? ???Fix?
We have a Laars LX400P Heater for our pool. It has been working fine but now the high limit switch has come on. There is a little bit of corrosion on the inside of the heater when you take off the panel. Any suggestions???
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Teledyne Laars Master
  • 1,448 Answers
Check up in the top of heater some come with resetable fusible links reset if possible or replace if heater is sooting check gas pressure if not enough pressure heater will overheat and trip that component clean out heat exchange if lower fusible link bad you might need a chimney stack
Posted on Feb 28, 2015
  • 640 Answers
This indicator normally means that your water temperature in the pool heater exceeds the internal limit. The corrosion should not be causing this problem. Since the high temperatures can be dangerous, you will probably have to contact a pool professional to service the machine.
Posted on Aug 12, 2010
How to chek hi limit switch
jump highlimit to see if it lights if so replace
May 27, 2014 | Jandy Laars LX Pool Heater / 400,000 BTU /...
How do i correct a "high limit switch circuit is open" code
check the fusable link for voltage on both sides if not replace also check pressure switch
May 26, 2014 | Jandy LX 400P Lo-NOx, 400,000 BTU Heater...
Laars LT - "red" light
means calling for heat if heater doesn't come on check safety circuits
Feb 12, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Where is the hi temp limit switch located?
where is the high temp limit switch located on my laars 44000 pool heater
Jun 02, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
(natural gas) the heater comes on for 3-5 minutes and then shuts off, and won't work again for hours. this is a shred heater between the pool and hot tub, but never used for the pool.
Check your high limit switch inside of the heater. Usually when the high limit switch pops it will take about 4 to 6 hours for it to reset itself without you resetting the system.
May 16, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy LX250 LT Pool Heater High Limit Switch
Jump the High limit switch. If it fires the switch is bad
Jul 16, 2009 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Laars Lt heater will not start- pressure switch light
it is time to check your filter make sure is not dirty and if your filter is clean and still doing this then the problem can be with one of the safety sensors they do have 2 hight limit switch located in the heater heather they re round with two wires on each one turn power off to heater and get a voltemer reader and check the hight limits for continuty they should read zero on your metter it can be your temp sensor heaters are so complicated that it is always good to have a pool tech service it I was a pool tech in california but now I am located in georgia
Jun 13, 2009 | Jandy Laars Lt 250,000 Btu Heater
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lx Pool Heater / 400,000 Btu / Propane Gas Logo
813 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
