Question about Craftsman 20 hp 42 in. Deck Yard Tractor
When I let the cluth brake out my engine shuts off
The engine shuts off as soon as I let the brake out
    Problem Solver:
  • 11 Answers
Sound like 1 of your safety switches is bad. mower will run with the brake on and your not on it. there should be a seat switch under the seat, there should be a blade engage switch somewhere on the chassis, and there is also a brake switch. trace your wire harness through out the mower and check each switch. you can check the switches by unplugging them and connecting a wire to each terminal in the plug to check each 1. if after you unplug a switch and use the wire and the mower stays running after you release the brake then that switch is bad....you can bypass the switches by leaving the wire connected to the plug.
Posted on Aug 16, 2009
ABS Brake light and check Engine soon light Won't shut off on my 2003 Diamante LS Mitsubishi how can I shut it off
have the fault codes read and fix what is shown up
could be a broken wire at one of the wheel sensors or something more serious
Apr 20, 2016 | 2003 Mitsubishi Diamante LS
Cluth not working no prusher in cluth handle fluid good do you have to bleed it if so how
To bleed the hydraulic clutch actuator on your GL1200, follow the hydraulic hose from the master cylinder down to where it attaches to the engine. In this area you will find a bleeder valve just like the ones on the brake calipers. You will need an 8mm box-wrench (don't use an open end wrench), and a piece of tubing to slip on the bleeder valve in order to prevent hydraulic fluid from running onto the engine.
Make sure the master cylinder is to the "Full" mark with clean DOT3 brake fluid and then begin by pumping the clutch lever several times. While holding the clutch lever in, loosen the bleeder valve briefly, then re-close it. Do not release the clutch lever while the bleeder valve is open (doing so will draw air back into the system).
Repeat the above steps five or six times while also keeping the fluid level in the master cylinder topped off. If pressure within the system is not restored, then you will need to repair / rebuild the master and slave cylinders.
May 23, 2010 | 1985 Honda GL 1200 Aspencade Gold Wing
Crusie control on 03 mack vision not working
it is ur cluth switch that is not letting ur cruise or jake brake works
May 23, 2009 | Melissa And Doug Big Rig Trucks
Engine dies off once brake/clutch is released
Your answer was perfect, when I located the saftey switch it was not working properly.
Thanks a million, Ron
Jan 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 2002 renault laguna, every now and again the cluth pedal stays in the down position and the car struggles to go in gear, once i lift the pedal back up into the normal position the clutch works...
try bleeding the cluth it sounds like you have air in the system.and have a look and se if the brakes and the cluth use the same fluid if there do bleed the brakes to
Sep 20, 2008 | Renault 18I Cars & Trucks
I can not pot my ford focus in gear i dont now what is is as cant finf cluth cable and the cluth peddel got no preass be hind it and my car is 2001 and do u now where the cluth is in the engean
yes the clutch is
well u have to take the gear box out
and the clutch is on the back of the engine
now the cable runs from the pedel to the gear box
if u look u will see a blck cable and you can adjust it
it might need adjusting
Aug 02, 2008 | 2000 Ford Focus
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
201 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
